Been a customer for a long time. CANNOT get DW 2015 to load up my WA Extensions.
Thread began 6/22/2015 1:02 pm by wb8sej | Last modified 7/29/2015 4:58 pm by Ray Borduin | 2705 views | 5 replies |
wb8sej
I have followed the "caution" warning, downloaded and installed the DW extensions with DW shut down. Will not appear. Have tried re-installing with DW running; will not show the WA extensions. REAL AGGRAVATION, since it makes WA a WAste of time and money. Anyone have the solution?
There is a bug in Dreamweaver CC 2015 that causes our extensions to not function properly. We are recommending people not do the update or install the previous version if you need to use our extensions. We will try to get an update out to address the problem as soon as possible.
jhood-fysh78990Beta Tester
I got extensions installed using DMXZone installer, but can not activate
Greetings, I did get the extensions installed, but now I get an error message (see attached screen print) when I try to activate the extensions. Is there a work around available?
The extensions are not currently compatible. We will be working on an update, but in the mean time you will have to install DW CC 2014 or earlier to work with webassist extensions.
nickj
Big fan of webassist but this is getting crazy. Any idea when we will able to use the current Dreamweaver?
PatriceWebAssist
See this thead: http://www.webassist.com/forums/posts.php?id=37620
