Blank confirm page
Thread begun 6/22/2015 3:36 am by Dave W | Last modified 6/22/2015 5:56 pm by Ray Borduin | 1992 views | 4 replies |
Dave W
Blank confirm page
Hello
For some reason the confirm page is now showing as blank. I have looked at and tried all the responces to this problem that are in the forum with no success.
The checkout works fine on my own local server, but shows a blank page with no shown errors when it's uploaded to the server.
Can you help?
I have attached my confirm.php page for you to have a look at.
It is probably missing files that weren't uploaded.
Try adding this to the top of the page:
ini_set('display_errors',1);
That should give you more information about why the page isn't displaying. If you still need help I'll need FTP access to debug the page and determine the problem.
Dave W
Hi Ray,
No luck. Tried adding the ini script (tried others before) but still showing blank page with no visable errors. Tried uploading all the site again and checking that the WebAssist folders had all their files in. All seems OK so am PMing FTP details.
Hope you can find the problem.
You had written a custom IF statement on the page using the empty() function... for some reason that function isn't defined on your server.
I rewrote the IF statements to not use that function and the page appears to be running properly now.
Dave W
Hi Ray,
Yes it works fine now. The IF statement must have been left there when i removed a function. I do have a habit of putting IF ELSE clauses for a function then fogetting to remove them when I remove that function, musy have missed that one. :-)
Thanks again for your prompt and effective help.
Dave
