Same as Billing checkbox not working
Thread begun 6/16/2015 9:38 am by eric284736 | Last modified 6/16/2015 4:50 pm by Ray Borduin | 1830 views | 4 replies |
eric284736
Hi Jason,
My Same as Billing checkbox does not work on eCart 6. The script is being called on the page.
Thx
Eric
Do you have a URL where I can view the problem? The "same as" functionality is in an external javascript, so I'd like to see it all in context to properly debug.
eric284736
Hi Ray,
Go to https://www.wolflaurelforhospice.org
You can add any item on the homepage to the cart to see the issue on the checkout.
thx
Eric
The same as functionality searches one set of fields within a fieldset and sets them to the same values from another fieldset.
It appears you have removed the <fieldset> tags from your form. You would have to add them back for it to work properly.
The fieldset ID attributes should be: "Billing" and "Shipping" respectively.
eric284736
Thanks Ray! That works!
