How to replace or rename image file name containing umluats or accents on file upload
Thread begun 6/13/2015 1:32 am by astrostrom | Last modified 6/15/2015 11:29 am by Ray Borduin | 2846 views | 1 replies |
astrostrom
Hello, as I am based in Europe I have a problem that people using our website and wishing to upload an image often have an umlaut, an accent or an empty space in their image file name such as: märz.jpg or le hôtel.jpg.
While the file will upload and the name will be inserted into the DB, the image will not display due to this problem.
In another thread I am asking about how to rename both the uploaded file and the text that is inserted into the DB with a number.
Another approach would be to remove the offending characters as discussed in the thread (Rejecting File Names with Wrong Characters - 11/26/2012) where Jason Byrnes wrote:
the following example will remove the & \ ' character, you can add others to the array:
if(isset($_FILES)) {
foreach($_FILES as $k => $v) {
$_FILES[$k]["name"] = str_replace(array("&","\\","'"),"",$_FILES[$k]["name"]);
Taking this approach I have added the following code to the top of mage page:
$_FILES[$k]["exhibition_image"] = str_replace(array("ä","ö","ü","é","à","é","ò","ô"," ","&","\\","'"),"",$_FILES[$k]["exhibition_image"]);
From the upload form:
<input name="exhibition_image" type="file" id="exhibition_image">
From the upload Server behavior:
$InsertQuery->bindColumn("exhibition_image", "s", "".((isset($_FILES["exhibition_image"]))?$_FILES["exhibition_image"]["name"]:"") ."", "WA_DEFAULT");
Unfortunately, both the uploaded image file as well as the file name text inserted into the DB still have the umlaut.
I am using the WA MySqli extension and WA DataBridge File Manipulation feature.
Any suggestions?
Thanks for your help.
You should be binding the value for the insert server behavior from the File Upload settings and the "Server File Name" value. If you get it from the $_FILES array it will have the original file name and not the one the upload renames it to.
