How to create a unique image file name containing umlauts or accents on upload?
Thread begun 6/12/2015 9:04 am by astrostrom | Last modified 6/19/2015 2:14 am by Ray Borduin | 6533 views | 8 replies |
astrostrom
The Problem:
Image file names that contain umlauts, accents or empty spaces do not display properly on the server once they are uploaded.
examples: märz.jpg, hôtel.jpg or march photo.jpg, hôtel à paris.jpg
Needed Solution:
I would like to be able to rename the uploaded image file with a unique file name that also gets inserted into the DB.
Example "märz.jpg" or "march photo.jpg" would be renamed to something like: "18732947.jpg" which also be inserted into the DB
On page 2 of the Digital File Pro Upload Wizard instructions it states:
Note: You may want to rename the file using a different naming convention by either: specifying a name directly, using the browse function, retrieving a name using available data bindings, or specifying server-side code to develop a dynamic naming convention.
Is this possible using any of the options above and, if so are there any examples / tutorials on how to do this?
You can specify a new file name on the second screen of the file upload server behavior. You could set it to the session_id() value to make it use a random number. (screen shot attached)
astrostrom
Dear Ray
Thanks for the quick reply. The screenshot is a bit too small to see clearly.
Perhaps you could post it again as a larger image.
I selected the session when I clicked on Lighting bolt.
<?php echo $_SESSION['']; ?>
But this gave me an error when I loaded the page.
Then I tried to get the session id which I am using to connect the form.
<?php echo $_SESSION['address_id']; ?>
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "../../exhibitions/",
'FileName' => "".$_SESSION['address_id'] ."",
'DefaultFileName' => "",
'ResizeType' => "2",
'ResizeWidth' => "205",
'ResizeHeight' => "120",
'ResizeFillColor' => "#FFFFFF" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
But this does not seem to change anything but I am not sure it is the right selection.
The original image name with the umlaut is still being inserted into the DB and the image file is uploaded to the upload folder - also with the original image name including the umlaut. I would like to be able to change (replace) both the file name with the umlaut and that which is inserted into the DB.
(BTW - I am using the mySQLi extension to generate the recordset and to manage the Insert Record)
Try:
'FileName' => "". session_id() ."",
astrostrom
Dear Ray
Thanks again for your reply. Your suggestion:
succeeded in renaming the uploaded image file (also with increments) into the image folder, however I have not been able to get the corresponding image name into the DB.
Obviously I need change something in the bind column but so far all my variations either give me the original file name or write a blank
Insert Record:
$InsertQuery->bindColumn("exhibition_image", "s", "".((isset($_FILES["exhibition_image"]))?$_FILES["exhibition_image"]["name"]:"") ."", "WA_DEFAULT");
File Manipulation:
'ResizeHeight' => "",
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if($_SERVER["REQUEST_METHOD"] == "POST"){
WA_DFP_UploadFiles("WA_UploadResult1", "exhibition_image", "2", "[NewFileName]_[Increment]", "true", $WA_UploadResult1_Params);
Upload Form:
<td><input name="exhibition_image" type="file" id="exhibition_image" value=""></td>
I can see the session_id with this code:
<?php echo session_id()?>
which I could put into the form if necessary.
It would be great to accomplish this last step.
Attached is an image file with umlauts,
Thanks for your help.
There are separate bindings added by the file upload server behavior that you should use instead of the form field for binding the inserted value to the database.
If you use that the result would be:
$InsertQuery->bindColumn("exhibition_image", "s", "".($WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"]) ."", "WA_DEFAULT");
astrostrom
Greetings again and thanks for your input.
However, as before, I am still not able to write the name of the file into the DB. I get a "blank" entry.
When I click on the File Manipulation SB Interface - I get the following error message.
"It appears that one of your server-side values is improperly coded. Please click this interface for inconsistencies."
Attached is the second page screen of the wizard.
Here is my code:
if ($_SERVER["REQUEST_METHOD"] == "POST") {
$InsertQuery = new WA_MySQLi_Query($mysqli2);
$InsertQuery->Action = "insert";
$InsertQuery->Table = "agenda_exhibition";
$InsertQuery->bindColumn("address_id", "i", "".((isset($_POST["address_id"]))?$_POST["address_id"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("exhibition_image", "s", "".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"] ."", "WA_DEFAULT");
$InsertQuery->bindColumn("exhibition_title", "s", "".((isset($_POST["exhibition_title"]))?$_POST["exhibition_title"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("exhibition_url", "s", "".((isset($_POST["exhibition_url"]))?$_POST["exhibition_url"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("exhibition_lead", "s", "".((isset($_POST["exhibition_lead"]))?$_POST["exhibition_lead"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("exhibition_init", "t", "".((isset($_POST["exhibition_init"]))?$_POST["exhibition_init"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("exhibition_exp", "t", "".((isset($_POST["exhibition_end"]))?$_POST["exhibition_end"]:"") ."", "WA_DEFAULT");
$InsertQuery->saveInSession("");
$InsertQuery->execute();
$InsertGoTo = "agenda_admin.php";
if (function_exists("rel2abs")) $InsertGoTo = $InsertGoTo?rel2abs($InsertGoTo,dirname(__FILE__)):"";
$InsertQuery->redirect($InsertGoTo);
Should I open a server ticket to troubleshoot this?
Best regards
Move the insert record code below the file upload code. I think it is just an issue with the position of the code on the page.
astrostrom
Dear Ray
Yes, Yes, Yes...That did it!
Thank you for your help.
