Does anyone have the server behaviour panel for dreamweaver cs6?
Thread begun 6/09/2015 5:06 pm by Php | Last modified 6/12/2015 4:52 pm by Ray Borduin | 5325 views | 15 replies |
Php
PatriceWebAssist
This might help: http://www.webassist.com/tutorials/Deprecated-Server-Behaviors-for-Dreamweaver-Creative-Cloud
It's for Creative Cloud, not cs6, and I can't remember how I did it for cs6, but might give you a few more words to search for on WebAssist forums.
Php
Hi there, thanks for helping out I originally had cc installed but having difficulty of applying img from databases table.. The function is not available in cc so I decided to download cs6 but now I can't find server behaviour for cs6 ? Anyhelp
Jamie
Sorry if I am missing th epoint, but do you mean where do you find access to it? If so, take al ook at: http://prntscr.com/7fcxt0
Hope that helps
Jamie
Php
Hi Jamie, sorry if I put incorrectly, what I meant to say was server behaviour add on that we normally download from adobe. The cc server behaviour add on I can't seem to find how to add the image thumb dynamically to web page? In the cs6 this function was available through insert image then data sources then select dynamic image with cc they got rid of this now I've done downloaded cs6 thought it might be easier to work with now I can't find the server behaviour add on ?
Kind regards
CS6 has server behaviors by default and you don't need an add on. In more recent versions you can still set a dynamic image source by using the bindings panel.
Php
Thanks for your response also when following this tutorial are we supposed to see the images or not i just have the path showing up??http://www.webassist.com/tutorials/Getting-started-with-MySQL-and-dynamic-websites
If just the path is showing on the page when you browse it then go to code view and wrap it in an image tag:
<img src="[path]">
Php
I did what you said still no image.. im following this tutorial.. im Stuck on step 4. Where is the image stored or should there a image or not?? Im i should see an image??
http://www.webassist.com/community/tutorials/view_tutorial.php?tid=104&accesscheck=%2Fcommunity%2Ftutorials%2Fview_tutorial.php%3Ftid%3D104
Your code looks correct. In dreamweaver you won't see an image. The image should display when you view the live page.
