Added a "Quick Cart" via Display Manager but the "View Cart" button doesn't link to anything, nor does it appear in the Server Behaviours panel?
Thread begun 6/09/2015 12:47 am by Nathon Jones Web Design | Last modified 6/11/2015 11:38 am by Ray Borduin | 10992 views | 5 replies |
Is this a bug with Quick Cart?
In Server Behaviours there is...
eCart Clear Cart Button
eCart Checkout Button
...but no View Cart.
1) Why is it doing this?
2) How do we tell it where to direct to when "View Cart" is clicked?
Thank you.
NJ
It tries to apply the Behavior "Go to Page"... but it appears Dreamweaver has removed that after DWCC.
The best solution is to just add an onclick event to go to the cart page on that button like:
onclick="document.location.href='cart.php'"
Here's what's inserted when we add a "Quick Cart" via Display Manager...
//WA eCart Include
require_once("WA_eCart/whiskyCART_PHP.php");
$whiskyCART->GetContent();
// WA eCart Clear Cart
if (isset($_POST["whiskyCART_Clear_100"]) || isset($_POST["whiskyCART_Clear_100_x"])) {
$whiskyCART->ClearCart();
$Redirect_redirStr="";
if ($Redirect_redirStr != "") {
$whiskyCART->redirStr = $Redirect_redirStr;
$whiskyCART->cartAction = "ClearCart";
//WA eCart Redirect Check Out
if (isset($_POST["whiskyCART_Checkout"]) || isset($_POST["whiskyCART_Checkout_x"])) {
if (isset($_SERVER['QUERY_STRING']) && $_SERVER['QUERY_STRING'] != "") {
if (strpos($Redirect_redirStr, "?") === false) {
$Redirect_redirStr .= "?".$_SERVER['QUERY_STRING'];
else {
$Redirect_redirStr .= "&".$_SERVER['QUERY_STRING'];
$whiskyCART->cartAction = "Checkout";
// WA eCart Redirect
if ($whiskyCART->redirStr != "") {
if (function_exists("rel2abs")) $whiskyCART->redirStr = rel2abs($whiskyCART->redirStr,dirname(__FILE__));
header("Location: ".$whiskyCART->redirStr);
die();
And the quick cart form itself, on the page..
<form action="<?php echo ($_SERVER["PHP_SELF"].(isset($_SERVER["QUERY_STRING"])?"?".htmlentities($_SERVER["QUERY_STRING"]):""));?>" method="post">
<div class="text-center">
<input name="whiskyCART_View_100" type="submit" class="btn btn-default" id="whiskyCART_View_100" onClick="MM_goToURL('plugins/plugins/parent','');" value="View Basket" />
<input type="submit" name="whiskyCART_Clear_100" id="whiskyCART_Clear_100" class="btn btn-default" value="Clear Basket" />
<input type="submit" name="whiskyCART_Checkout" id="whiskyCART_Checkout" class="btn btn-default" value="Checkout" />
</div>
</form>
What I'm asking is why isn't the "View Cart" button working? I'm asking that Ray because if the extensions don't do what they're supposed to I don't have hours of time to waste finding that out the hard way - ie. applying them and them just not working. Are you telling me that Quick Cart doesn't work in Dreamweaver CC?
Also, your onclick suggestion...is there a reason you've added the "plugins" subdirectory to that link?
Thank you.
NJ
The reason why it isn't working is what I've stated above.
The button has a behavior attached to it:
but MM_goToURL() has been depricated and removed from dreamweaver, so the solution is to add the onclick I suggested instead.
The link is just a random string... it should be the location and name of your cart page wherever it is.
It was eCart that inserted the MM_goToURL() code when we opted for the Quick Cart option from Display Manager.
Is what you're saying basically that eCart inserts depricated code and we'll have to hand code it to fix it?
Thank you.
NJ
Yes, that is correct. The view cart button is simply a link. It doesn't have a server behavior or special code for it to work. It simply links to the cart page.
In fact you always had to type in the cart page by hand after application in every version of eCart because we don't ask you to specify the cart page when running the display manager... so the view cart link always had to be added manually after running the wizard.
