Mobile friendly web sites
Thread begun 6/05/2015 4:33 am by Cheyanne | Last modified 8/12/2015 11:04 pm by Ray Borduin | 8778 views | 13 replies |
Cheyanne
We all know that web site design has changed dramatically over the recent years. The latest trend is to make web sites mobile friendly. My question is simply this "Are WebAssist" products mobile friendly?. I have a large commercial web site which has a CSS Menu attached to it. How would I make a large menu, like this, which has sub menus and sub-sub menus mobile friendly?
There is more than one way to make a menu responsive.
A popular option is to display a menu icon and make the menu hidden until accessed (see our site on mobile).
This is a relatively easy adjustment you can make to a WebAssist menu built with menu writer. It hasn't been integrated directly into the tool yet, but if you post a site with a menu you want help converting we can help you with the necessary CSS from this forum.
Cheyanne
Responsive menus
Many thanks for your prompt reply. The web site in question is www.alanco-alalamtic.com. I was unsure as to exactly what you wanted me to post do you need the CSSMenuWriter folder or simply files from within it? If so please enlighten me as to what you want me to send you.
That web url doesn't seem to work for me. Please check for typos and post back.
Cheyanne
Hi Ray
The domain is http://www.alanco-alamatic.com/ - taken directly from the browser window. Apologies for the previous typos.
OK, so here is an example of how to make this page mobile friendly.... first you add a viewport meta tag to the header:
<meta name="viewport" content="width=device-width, initial-scale=1">
Then you define a mobile css file (attached)
Then add a menu icon to open and close the menu just above your menu UL tag like:
<div id="phoneMenu"><img src="Images/menu_white.png" alt="View Menu" onclick="hideshowmenu()"></div>
I've attached the image you can add to your images folder for the menu icon.
Then add javascript to open and close the menu when it is clicked (attached)
mrobben375515
I like the idea of keeping the responsive css and js outside in separate files like you appended to this tread. I am using ecart6 and it seems to make sense for me to add that call to css and js in my main.dwt file. Do you agree? If so, what code should I add to my main.dwt and where should I place that code?
The code is going to be different based on your template.
The code I gave to the previous user was very specific to their site. The menu portion may work if you used our menu writer, but other than that you would have to create your own responsive.css to match your template.
Yes, you would add it to your template. Most likely adding the .css file to your head tag and the script reference just above the </body> tag.
mrobben375515
I am using the ecart6 files as extracted from the zip, and I using the WA tools included in Design Extender, Data Bridge, and MySQLi Server Behaviors. In the existing main.dwt.php template, in the header section I see @import url("../css/common.css"), @import url("../css/content.css"), @import url("../css/content_print.css"), @import url("../CSSMenuWriter/cssmw_home/menu.css"), <link href="../SpryAssets/SpryAccordion.css">, @import url("../css/home.css"), @import url("../css/spry_custom.css"), and finally @import url("../css/mystyles.css"). Does the @import url("../css/responsive.css") in the header need to go above or below any of these so as not to conflict with any of the existing .css calls?
I only see (2) .js references in this template and both are in the header so I don't anticipate any problems placing the other script before the </body>
I'd put the responsive css at the bottom. For the most part you want to make sure it overwrites any css defined earlier.
