Radio Group not returning checked value in repeating table
Thread begun 6/03/2015 9:43 pm by Paul | Last modified 6/08/2015 12:47 pm by Ray Borduin | 1759 views | 2 replies |
PaulBeta Tester
Tweak required for following to return the selected option button when page is refreshed - it currently returns nothing!
<input <?php if (!(strcmp($row_rsGetUser['PicImagePrime'],$row_rsGetUser['PicID']))) {echo "checked=\"checked\"";} ?> type="radio" id="UsrImgPrime_<?php echo $row_rsGetUser['PicID']; ?>" name="UsrImgPrime" value="<?php echo $row_rsGetUser['PicID']; ?>">
Where rsGetUser is two joined tables.
Any ideas anyone?
This code attempts to select the checkbox on the row where the value for 'PicImagePrime' is equal to the value of ''PicID'
So if it isn't working, that could mean that either that value isn't set correctly in the database for the PicImagePrime field, or that the Recordset values aren't correct.
I'd probably start debugging by writing the values before the radio buttons like:
<?php echo($row_rsGetUser['PicImagePrime']); ?>:<?php echo($row_rsGetUser['PicID']); ?>
then see if there is a row in which they do match. It would appear that there isn't. Then you need to figure out why or more specifically what value instead of <?php echo($row_rsGetUser['PicImagePrime']); ?> would match <?php echo($row_rsGetUser['PicID']); ?> on the radio that should be selected.
Without context and an understanding of the rest of the page it is impossible for me to suggest the solution, but hopefully this insight will help you to debug it on your own.
PaulBeta Tester
Thanks for the steer ray.
Turns out my recordset rsGetUser had two identical entries, one form each table i joined. Obviously this was caussing some conflict.
After removing one, ive now got my radio button populating as expected.
