File Upload Validation Query
Thread begun 5/29/2015 10:53 am by Paul | Last modified 6/03/2015 1:33 pm by Ray Borduin | 5827 views | 8 replies |
PaulBeta Tester
Using DB to create an upload function.
I've created an image width (max pixel value 940) validation, however, if it is found to exceed this value during upload, the file continues to save to the server - it doesn't fail and prevent save.
if (isset($_POST["nhSendUpload"]) || isset($_POST["nhSendUpload_x"])) {
$WAFV_Redirect = "";
$_SESSION['WAVT_nhAddPhoto1_202_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateNM(((isset($_POST["nhImageLoadSize"]))?$_POST["nhImageLoadSize"]:"") . "",1,50000,"",",.",true,2);
$WAFV_Errors .= WAValidateNM(((isset($_POST["nhImageLoadWidth"]))?$_POST["nhImageLoadWidth"]:"") . "",1,940,"",",.",true,1);
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"nhAddPhoto1_202");
Any ideas why this is so?
Where are you getting the bindings for the size and width? They appear wrong. Can I see a copy of the page?
PaulBeta Tester
They are from my upload form.
Page attached.
Two things... first the validation appears below the database insert code. In order for it to prevent the insert you would have to put the validation below the file upload code and above the insert code.
Second the validated values appear wrong. I think it should be:
if (
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateNM(((isset($_FILES["nhImageUpload"]))?$_FILES["nhImageUpload"]["size"]:"") . "",1,50000,"",",.",true,2);
$WAFV_Errors .= WAValidateNM(((isset($_FILES["nhImageUpload"]))?$_FILES["nhImageUpload"]["width"]:"")  . "",1,940,"",",.",true,1);
if (
PaulBeta Tester
I get the role of the validation being placed before the insert.
However despite the two changes, images are failing validation and saving to my server.
They are not inserting into my database though, so its kinda getting there.
I'm wondering if its because the image file size is being reduced to below the validation limit.
100Kb + files are for some reason reducing to less than 40Kb after uploading still !
You would have to move the validation above the upload code too if you wanted it to stop the file upload from taking place.
PaulBeta Tester
Ok so taking a verbose approach to my validation;
If the file size is between 1 - 50,000 Kb, upload to server
AND
If the image width is between 1 - 940 pixels, insert a record
If both these conditions are true during validation then the file should be uploaded and a record inserted.
Based on this, I have created the following WA Validation;
$WAFV_Errors = "";
This code sits above the WA insert and upload server behaviors.
I am uploading a .jpg file 40Kb in size and 620 pixels in width, both meet my validation criteria and should not fail.
I am creating a thumbnail at the same time, but it is not being validated.
For some reason the upload is failing on one or both validations
If i remove the validation behavior, the file uploads perfectly, so the issue lays with how the validation is constructed.
Have i understood this correctly?
The issue is that the width won't be set automatically. The webassist upload sets it, but if you put the validation after that it will have already uploaded the file.
The solution is to set the width manually using the getimagesize() function.
If you add this code above the validation:
if (isset($_FILES)) {
$image_info = getimagesize($_FILES["nhImageUpload"]["tmp_name"]);
$_FILES["nhImageUpload"]["width"] = $image_info[0];
That should add the width attribute to the files array and allow you to validate it.
PaulBeta Tester
I think i get that!
Anyways, your solution and advice has worked. Thanks.
