path is wrong to custom upload folder
Thread begun 5/26/2015 2:35 pm by jo271221 | Last modified 6/08/2015 4:55 pm by Ray Borduin | 1648 views | 2 replies |
jo271221
This files are getting uploaded to the server just fine with this configuration but the path that is getting inserted is
/http:/mysite.com/userfiles/6725/3rdBarrel.jpg One forward slash before the url and only one after the http I tried both with and without www. This is working on another site of mine (CHot file)
I have attached the config files from each site. Thank You!! Also will this same config file control the browse (not file manager but simple browse or do I have to do something else to insert the webprefix in front of those files? Thanks
jo271221
userfile path
I am still having issues with the userfiles directory.
1. Uploading Images - File Path
All image uploads should insert/update into the directory /userfiles/999 with 999 being the id from the tbl_directorylistings or customerid from other tables.
All image inserts (create and update pages) should insert the full path to the database ie hotlinewebsites.com/userfiles/999/profile or 999/horses etc
accounts/update_profile_pics_about.php line 159 - This change is made in the interface - Jo 6/3/15 2015 str_replace("#","#",$CKEditor_config["uiColor"]):"#eee")."&theme=webassist_v2&showsidebar=false&startup_folder=/hotpage/"; The forward slash before hotpage removes the userfile folder function
str_replace("#","#",$CKEditor_config["uiColor"]):"#eee")."&theme=webassist_v2&showsidebar=false&startup_folder=hotpage/"; This code will insert to the correct users directory but till NOT work because the path is userfiles/6636hotpage/myimage.jpg
Related Question - Will upload, file manager and html editor all on one update page create a problem? http://hotlinewebsites.com/manage/post_update_basic.php?postid=2805 (html editor is uploading to userfiles )
I need to insert the full path - Likely a paid support item but I would like to resolve the above first if possible
I fixed your config file and had to update: /kfm/plugins/return_url/plugin.js to get it to work.
