IF / ELSE statements & foreach loops using the MySQLi plugin?
Thread begun 5/19/2015 2:00 pm by Jason | Last modified 6/04/2015 3:01 pm by Ray Borduin | 5183 views | 8 replies |
Jason
I was wondering if there is a way to do some of the functions using the plugin. I've hand written them into my code for now, and they are working, but I'd like to still be able to use my plugin. Currently it doesn't recognize the queries I've made changes to (understandably). This is the code I have working now.
$_POST
['calendar_id'] = 1;
if ((((isset(
$_POST["Submit"]))?$_POST["Submit"]:"") != "")) {
        foreach(
$_POST['Room'] as $room)
$InsertQuery = new WA_MySQLi_Query($local_i);
$InsertQuery->Action = "insert";
$InsertQuery->Table = "calendarevents";
$InsertQuery->bindColumn("calendar_events_name",       "s", ((isset($_POST["insert_id"]))?$_POST["insert_id"]:""), "WA_DEFAULT");
$InsertQuery->bindColumn("calendar_events_start_date", "s", ((isset($_POST["start_date"]))?$_POST["start_date"]:date('Y-m-d')), "WA_DEFAULT");
$InsertQuery->bindColumn("calendar_events_end_date",   "s", ((isset($_POST["start_date"]))?$_POST["start_date"]:date('Y-m-d')), "WA_DEFAULT");
$InsertQuery->bindColumn("calendar_events_start_time", "s", ((isset($_POST["start_time"]))?$_POST["start_time"]:""), "WA_DEFAULT");
$InsertQuery->bindColumn("calendar_events_end_time",   "s", ((isset($_POST["end_time"]))?$_POST["end_time"]:""), "WA_DEFAULT");
            if(isset(
$_POST['Recurring']))
$InsertQuery->bindColumn("calendar_events_repeats",        "s", ((isset($_POST["RecurType"]))?$_POST["RecurType"]:""), "WA_DEFAULT");
$InsertQuery->bindColumn("calendar_events_repeat_every",   "i", ((isset($_POST["Frequency"]))?$_POST["Frequency"]:""), "WA_DEFAULT");
$InsertQuery->bindColumn("calendar_events_on_the",         "i", ((isset($_POST["dow"]))?$_POST["dow"]:""), "WA_DEFAULT");
$InsertQuery->bindColumn("calendar_events_repeat_on",      "i", ((isset($_POST["RecurOn"]))?$_POST["RecurOn"]:""), "WA_DEFAULT");
$InsertQuery->bindColumn("calendar_events_occurrence",     "s", ((isset($_POST["Occurrence"]))?$_POST["Occurrence"]:""), "WA_DEFAULT");
$Occurrence_End = ((isset($_POST["Occurrence"]) && $_POST['Occurrence'] == 'end-by-end-date')?$_POST["ends_on"]:$_POST['EndAfter']);
$InsertQuery->bindColumn("calendar_events_occurrence_end", "s", $Occurrence_End, "WA_DEFAULT");
$InsertQuery->bindColumn("calendar_events_occurrence_storage", "s", $Occurrence_End, "WA_DEFAULT");
$InsertQuery->bindColumn("calendar_events_type",        "s", (isset($_GET['type']) ? $_GET['type'] : "person"), "WA_DEFAULT");
$InsertQuery->bindColumn("calendar_events_attribute",   "s", $room, "WA_DEFAULT");
$InsertQuery->bindColumn("calendar_events_attribute_2", "s", ((isset($_POST["Position"]))?$_POST["Position"]:""), "WA_DEFAULT");
$InsertQuery->bindColumn("calendar_events_event_list",  "i", $Parent_Event_List, "WA_DEFAULT");
$InsertQuery->bindColumn("calendar_events_calendar_id", "i", ((isset($_POST["calendar_id"]))?$_POST["calendar_id"]:"1"), "WA_DEFAULT");
$InsertQuery->bindColumn("calendar_events_attribute_3", "s", "".((isset($_POST["Category"]))?$_POST["Category"]:"")  ."", "WA_DEFAULT");
$InsertQuery->bindColumn("calendar_events_shift_event_parent_id", "i", "".((isset($_GET["calendar_events_id"]))?$_GET["calendar_events_id"]:"")  ."", "WA_DEFAULT");
$InsertQuery->execute();
        if(
count($_POST['Room']) > 1)
$InsertGoTo = "event_schedule.php?day=".((isset($_POST["start_date"]))?$_POST["start_date"]:date('Y-m-d'))
"&calendar_events_id=".((isset($_GET["calendar_events_id"]))?$_GET["calendar_events_id"]:"1")
"&calendar_events_event_list=".($Parent_Event_List);
        else
"&calendar_events_attribute=".((isset($_POST["Room"][0]))?$_POST["Room"][0]:"")
    if (
function_exists("rel2abs")) $InsertGoTo = $InsertGoTo?rel2abs($InsertGoTo,dirname(__FILE__)):"";
$InsertQuery->redirect($InsertGoTo);
How can I make this work with the MySQLi plugin?
Is there a way to write loops and IF statements in the plugin?
You could probably do it using WA_IGNORE
So instead of:
if(isset($_POST['Recurring']))
you could use:
$InsertQuery->bindColumn("calendar_events_repeats", "s", ((isset($_POST["Recurring"]))?$_POST["RecurType"]:""), "WA_IGNORE");
The final argument tells it what to do when the value is blank. If you use WA_IGNORE it will essentially ignore that line if a blank value is passed in. That should allow you to do conditional column settings without breaking inspection.
Jason
Made those changes, and the code still seems to function correctly, but the plugin still doesn't recognize the insert query. Did I miss something?
$_POST
if ((((isset(
        foreach(
$InsertQuery->bindColumn("calendar_events_repeat_every",  "i", ((isset($_POST["Recurring"]))?$_POST["Frequency"]:""), "WA_IGNORE");
$InsertQuery->bindColumn("calendar_events_on_the",        "i", ((isset($_POST["Recurring"]))?$_POST["dow"]:""), "WA_IGNORE");
$InsertQuery->bindColumn("calendar_events_repeat_on",     "i", ((isset($_POST["Recurring"]))?$_POST["RecurOn"]:""), "WA_IGNORE");
$InsertQuery->bindColumn("calendar_events_occurrence",    "s", ((isset($_POST["Recurring"]))?$_POST["Occurrence"]:""), "WA_IGNORE");
$Occurrence_End = ((isset($_POST["Recurring"]) && $_POST['Occurrence'] == 'end-by-end-date')?$_POST["ends_on"]:$_POST['EndAfter']);
$InsertQuery->bindColumn("calendar_events_occurrence_end", "s", $Occurrence_End, "WA_IGNORE");
$InsertQuery->bindColumn("calendar_events_occurrence_storage", "s", $Occurrence_End, "WA_IGNORE");
        if(
        else
    if (
Little things like extra line breaks, unexpected tabs, and quotes out of place could cause it to not be recognized.
This line looks right:
This one doesn't:
it would probably be recognized with:
$InsertQuery->bindColumn("calendar_events_end_time", "s", "".((isset($_POST["end_time"]))?$_POST["end_time"]:"")  ."", "WA_DEFAULT");
You would probably have to go through each line to match that syntax before it would be picked up by the UI.
Jason
Ok, I'll give that a shot.
Is there a way to do an OR statement on the UPDATEQuery
For example
$UpdateQuery->addFilter("calendar_events_id", "=","i", ((isset($_POST["ShiftID"]))?$_POST["ShiftID"]:"")) OR ("something_else", "=", "i", ((isset($_POST["ShiftID"]))?$_POST["ShiftID"]:"")) OR ("something_else_2", "=", "i", ((isset($_POST["ShiftID"]))?$_POST["ShiftID"]:""));
That isn't supported in the current version. We will be adding more advanced Searching functions in the next update.
Jason
I made the changes you suggested (and a few others), but there's still something that the plugin doesn't recognize. Any ideas?
$_POST
if ((((isset(
        foreach(
$_POST['room'] as $room)
$InsertQuery->Table = "schedule";
$InsertQuery->bindColumn("schedule_name", "s", "".((isset($_POST["person_id"]))?$_POST["person_id"]:"")  ."", "WA_DEFAULT");
$InsertQuery->bindColumn("start_date", "s", "".((isset($_POST["start_date"]))?$_POST["start_date"]:date('Y-m-d'))  ."", "WA_DEFAULT");
$InsertQuery->bindColumn("end_date", "s", "".((isset($_POST["start_date"]))?$_POST["start_date"]:date('Y-m-d'))  ."", "WA_DEFAULT");
$InsertQuery->bindColumn("start_time", "s", "".((isset($_POST["start_time"]))?$_POST["start_time"]:"")  ."", "WA_DEFAULT");
$InsertQuery->bindColumn("end_time", "s", "".((isset($_POST["end_time"]))?$_POST["end_time"]:"")  ."", "WA_DEFAULT");
$InsertQuery->bindColumn("repeats", "s", "".((isset($_POST["Recurring"]))?$_POST["RecurType"]:"")  ."", "WA_IGNORE");
$InsertQuery->bindColumn("repeat_every", "i", "".((isset($_POST["Recurring"]))?$_POST["Frequency"]:"")  ."", "WA_IGNORE");
$InsertQuery->bindColumn("on_the", "i", "".((isset($_POST["Recurring"]))?$_POST["dow"]:"")  ."", "WA_IGNORE");
$InsertQuery->bindColumn("repeat_on", "i", "".((isset($_POST["Recurring"]))?$_POST["RecurOn"]:"")  ."", "WA_IGNORE");
$InsertQuery->bindColumn("occurrence", "s", "".((isset($_POST["Recurring"]))?$_POST["Occurrence"]:"")  ."", "WA_IGNORE");
$InsertQuery->bindColumn("occurrence_end", "s", $Occurrence_End, "WA_IGNORE");
$InsertQuery->bindColumn("occurrence_storage", "s", $Occurrence_End, "WA_IGNORE");
$InsertQuery->bindColumn("type", "s", "".(isset($_GET['type']) ? $_GET['type'] : "person")  ."", "WA_DEFAULT");
$InsertQuery->bindColumn("room", "s", $room, "WA_DEFAULT");
$InsertQuery->bindColumn("position", "s", "".((isset($_POST["Position"]))?$_POST["Position"]:"")  ."", "WA_DEFAULT");
$InsertQuery->bindColumn("event", "i", $Parent_Event_List, "WA_DEFAULT");
$InsertQuery->bindColumn("schedule_attribute", "s", "".((isset($_POST["Category"]))?$_POST["Category"]:"")  ."", "WA_DEFAULT");
$InsertQuery->bindColumn("parent_event_id", "i", "".((isset($_GET["schedule"]))?$_GET["schedule"]:"")  ."", "WA_DEFAULT");
        if(
count($_POST['room']) > 1)
            $InsertGoTo
= "". "event_schedule.php?day=".((isset($_POST["start_date"]))?$_POST["start_date"]:date('Y-m-d'))
"&schedule=".((isset($_GET["schedule"]))?$_GET["schedule"]:"1")
"&room="
."&event=".($Parent_Event_List)
"&calendar=".((isset($_GET["calendar"]))?$_GET["calendar"]:"0") ."";
            if (
        else
            $InsertGoTo
"&room=".((isset($_POST["Room"][0]))?$_POST["Room"][0]:"")
            if (
You can't hand edit any code within the code chunk written by the server behavior. You should instead add any loops or if statements outside of the code chunk to achieve your results and allow further edits through the UI. Here is an example of rewriting your code so that it has all of your custom code but can still be recognized by Dreamweaver:
$_POST
if ((((isset(
  foreach(
$_POST['room'] as $room) {
if ((((isset($_POST["Submit"]))?$_POST["Submit"]:"") != "")) {
$InsertQuery->bindColumn("occurrence_end", "s", "".$Occurrence_End  ."", "WA_IGNORE");
$InsertQuery->bindColumn("occurrence_storage", "s", "".$Occurrence_End  ."", "WA_IGNORE");
$InsertQuery->bindColumn("room", "s", "".$room  ."", "WA_DEFAULT");
$InsertQuery->bindColumn("event", "i", "".$Parent_Event_List  ."", "WA_DEFAULT");
$InsertQuery->saveInSession("");
$InsertGoTo = "";
  if (
  if(
$InsertGoTo = "". "event_schedule.php?day=".((isset($_POST["start_date"]))?$_POST["start_date"]:date('Y-m-d'))
"&room="
      if (
  else
      if (
Notice that all of the hand code was added either before or after the chunk of code controlled and written by the server behavior so that it can continue to be in charge of that area.
Jason
Perfect! Thanks again Ray! You are awesome as usual!
