Syntax Error when following coupon code tutorial
Thread begun 5/19/2015 2:53 am by sfranzken73972 | Last modified 5/19/2015 2:42 pm by Ray Borduin | 1559 views | 4 replies |
sfranzken73972
It says there is a syntax error on line 17; line 17 for me is where the if line starts
@session_start();
if((Recordset: rsCoupon is not empty != "")) {
$_SESSION["PromoAmount"] = "".$row_rsCoupon['CouponAmount'] ."";
Lastly once you create a WA Session how do you get back to the interface to modify it?
It looks like it put in the trigger wrong. Delete that code chunk and try re-applying the set session value server behavior.
sfranzken73972
Thanks Ray
That worked and is there way to get back to the WA interface for session variables once one is created?
You have to move the code from lines 17-22 down below the recordset that ends on line 72.
You should be able to edit the Save Session Value server behavior by double-clicking on it in the Server Behaviors window after application.
sfranzken73972
That did it
Thanks Ray will be in touch shortly to setup a premium support ticket for the TransFirst gateway.
