update not updating
Thread begun 5/13/2015 10:47 am by LionsMane | Last modified 5/13/2015 11:31 am by Ray Borduin | 2649 views | 5 replies |
LionsMane
update not updating
I have a simple Update function using the mysqli tools, but the form is failing to update the record, and it's pretty simple. Only one field is being updated, and it's the right field/data type. The appropriate column and ID appears to be in the code. The script is redirecting as expect, but the record simply isn't being updated, and there's no error. Help??? Page attached.
Your hidden field for the parcel id seems to be set wrong. You have:
<input name="ParcelID" type="hidden" id="ParcelID" value="<?php echo((isset($_POST["ParcelID"]))?$_POST["ParcelID"]:"") ?>">
and I think it should be:
<input name="ParcelID" type="hidden" id="ParcelID" value="<?php echo($Recordset1->getColumnVal("ParcelID")); ?>">
LionsMane
Gah.. you're absolutely right. You guys are awesome if for nothing else, then a great second set of eyes to help catch this little stuff. THx again
LionsMane
working code
PM
You have to update your <form> tag and add method="post"
LionsMane
Wow.. it's those little things, right?
