Is Payline Data a payment gateway that can be used with ecart 6
Thread begun 5/12/2015 4:17 pm by JBWebWorks | Last modified 5/13/2015 9:45 am by Ray Borduin | 2543 views | 3 replies |
JBWebWorks
Just bought ecart 6 and have a client that wants to use Payline Data as their gateway.
You can still use eCart, but the Payline implementation part would have to be done by following their documentation. I'd probably run the eCart wizard with Authorize.net as the payment gateway and then edit the authorize.net code to payline after. This is something we could help you with in a premier support ticket. I'm sure it could be done in an hour or two.
JBWebWorks
Thanks Ray. I will contact you if i need the premier support.
What is the best way to request that?
You can request premier support from this page: http://www.webassist.com/premier_request.php
