Insert Multiple Records
Thread begun 5/12/2015 8:20 am by Mushroom-Graphics | Last modified 5/20/2015 11:03 am by Ray Borduin | 5951 views | 5 replies |
Mushroom-Graphics
I get the following error after I built a form to insert multiple records into a table:
Parse error: syntax error, unexpected 'else' (T_ELSE), expecting while (T_WHILE) in C:\xampp\htdocs\SpitzWeiss\bayside_beat\Admin\homes_add_images.php on line 123
If I had to guess I think it is because I have a dynamic filled list of addressed in the form. Not sure what to do.
You have some bad code on lines 114-115 related to the dynamically populated select list.
Move the hidden form element on line 115 to lower on the page on line 120.
Then delete line 114 and delete lines 110-112.
Now you can probably use the property inspector to re-populate the select list from the recordset and hopefully dreamweaver will apply the code correctly this time.
Mushroom-Graphics
That seemed to work, thank you. Now the trouble I am having is with the file upload and inserting the file name into the table. I make the form then set it up so it will upload the file to the images folder then insert the info into the table. Then I do the repeat section, then populate the addresses using the properties bar. I don't get any errors. The file uploads but the name is not inserted into the table. It also seems to not adhere to the rule that if there is no picture file listed to upload then skip it.
File upload doesn't currently work with multiple rows.
You would have to do some hand coding to repeat the upload and store it as separate variable's to get this to work. This is something we could help with in a premier support ticket.
Mushroom-Graphics
Contacted premium support but never heard anything
I just called and scheduled this with you. Sorry for the delay.
