CDONTS to CDOSYS - Classic ASP
Thread begun 5/08/2015 9:18 am by Nathon Jones Web Design | Last modified 5/21/2015 2:25 pm by Ray Borduin | 2852 views | 2 replies |
Our host has just upgraded all of their 2003 Windows servers to 2008 and, in doing so, have turned off CDONTS.
Thing is, a lot of my old sites are coded in Classic ASP and I, therefore, can't use the new UE extension to upgrade them.
Is there an easy way switch the existing script, CDONTS_NewMail_VB.asp (attached), to CDOSYS?
Also, I attach a screenshot of a weird thing that's been happening with your forum recently on both IE and Firefox when you try to create a new post. Hope that can be sorted because I'm having to type my entire post out in Notepad and then paste it in.
Thank you.
NJ
I could only reproduce the issue with the popup position in IE, but I got it fixed.
Do you have an older version of Dreamweaver you can install the old version of UE on to update the page with?
I have attached a copy of the CDO_SYS version of the include file... if you are lucky you may just be able to replace that and it will all work. It has been many years since I've dealt with an ASP page, so I can't be sure but it is worth a shot.
It looks like on line 25 you have:
set WA_MailObject = WAUE_Definition()
It should use the syntax:
set WA_MailObject = WAUE_Definition(host,port,timeout,username,password,useAuth)
try leaving them all but the host setting blank like:
set WA_MailObject = WAUE_Definition("localhost","","","","","")
