Image upload issue with size restrictions
Thread began 5/08/2015 8:42 am by sandy170299 | Last modified 1/14/2016 11:05 am by Ray Borduin | 1344 views | 4 replies |
sandy170299
This is absolutely not going to work for me and I need to know how to change it. I need to upload images which are exactly 1055 pixels wide, but I'm getting an error message that says: "Please do not upload images which are larger than 1024x768" and it won't allow an upload. If I can't change this, I can't use Power CMS! Thank you.
This is set in the KFM settings file here: webassist/kfm/initialise.php. You will see this setting on lines 133-134 and can easily be updated for larger images.
sandy170299
Excellent - thank you. :)
russb335115
can you tell me how to change the file size limit? I need to be able to upload a 30meg file.
Is this with KFM? Is it an image? You may need to update the webassist/kfm/initialise.php file, but you could also have to update the php.ii settings for these two values:
upload_max_filesize
post_max_size
