customizing a detail page.
Thread begun 5/05/2015 3:43 am by Kumel | Last modified 6/23/2015 11:44 pm by Ray Borduin | 8756 views | 30 replies |
Kumel
i got an website for artworks.
where admin can upload the artworks and etc.
site link: http://www.shrishtiart.com/
artworks page: http://www.shrishtiart.com/artworks.php
Now from artworks.php if you choose an artwork then your taken to artwork-details.php?id=44 or so....
Now within that page (artwork-details.php) there is next & prev.
Here when i click next or prev it just takes to next artwork.
But in artworks.php page the order is: ORDER BY `position` ASC
so i wanna use same in artwork-details.php when someone clicks next it should show next artwork shown in artworks.php page.
Example: 4th artwork here is: id=356 "WHITE SCULPTURE ARTWORK" "Chippa Sudhakar" (http://www.shrishtiart.com/artworks.php)
So then when i m in http://www.shrishtiart.com/artwork-details.php?id=356 and when i click next i must be taken to : http://www.shrishtiart.com/artwork-details.php?id=64 but instead it takes me to: id=357 .
So how do i solve this?
Is the value for the position column in the database unique? If not you would want to ORDER by both the position and the id for consistency between pages.
You are going to have to order by the same columns on the details page that you did on the results page for your next and previous recordsets. Then you are going to also filter based on the position of the current record and not the id of the current record. To do this you would probably want to store the value from the first recordset into a $_GET variable after the main recordset but before the previous and next recordsets like:
$_GET['position'] = $row_WADAartworks['position'];
Now you would update your next and previous recordsets to find their positions based on the current postion (and ID if position isn't unique).
It might look like:
SELECT id FROM artworks WHERE position > %s ORDER BY position, id LIMIT 1
If position isn't unique it would be:
SELECT id FROM artworks WHERE position > %s and id > %s ORDER BY position, id LIMIT 1
Kumel
the value for the postion column is not unique.
I added this after WADAartworks RS:
So now where do i add this: SELECT id FROM artworks WHERE position > %s and id > %s ORDER BY position, id LIMIT 1
You are going to have to update both your previous and next recordsets to use both position and ID for ordering... you will have to also update the recordset on the results page.
Kumel
artwork-details.php :
rsnextid:
SELECT id
FROM artworks
WHERE id > colname
colname: $_GET['id']
rspreviousid:
SELECT id
FROM artworks
WHERE id < currentid
ORDER BY id DESC LIMIT 1
currentid: $_GET['id']
rsminmaxid:
SELECT min(id) AS MinID, max(id) AS MaxID
FROM artworks
Above are details of artwork-details.php
So from above 3 RS where we need to change?
"you will have to also update the recordset on the results page"
results page is artworks.php
ie: http://www.shrishtiart.com/artworks.php
file attached
Kumel
well i got the basic idea for it. attached artworks-details.php file.
Next seems to work.
But what not prev. not sure what needs to be done.
Next would be:
"SELECT id FROM artworks WHERE position >= %s and id > %s ORDER BY position, id LIMIT 1"
and prev would be:
"SELECT id FROM artworks WHERE position <= %s and id < %s ORDER BY position DESC, id DESC LIMIT 1"
The position comparison has to be >= not just > because it might be the same as the previous.
Kumel
for next this seems to work:
"SELECT id FROM artworks WHERE position > %s and id > %s ORDER BY position, id LIMIT 1"
but for prev this doesn't work :
Prev a href:
"artwork-details.php?id=<?php echo $totalRows_rspreviousid == 0 ? $row_rsminmaxid['MaxID']:(isset($_GET['id'])?$row_rspreviousid['id']:1);?>"
Next a href :
"artwork-details.php?id=<?php echo $totalRows_rsnextid == 0 ? $row_rsminmaxid['MinID']:(isset($_GET['id'])?$row_rsnextid['id']:1);?>"
Kumel
I got an artist page : http://www.shrishtiart.com/artists.php
Lets say i choose an artist ie: http://www.shrishtiart.com/artist/achuthan-kudallur
Then artist's artworks are displayed.
Now when i click on 1st artwork: Art ID=164
i m taken to: http://www.shrishtiart.com/artwork-details.php?id=164
So now when i click next from botttom then i must be taken to next artwork of same artist so how is it done?
DB Structure Attached.
artwork-details page also attached. the next button seems to work but not prev botton.
I've thought about this more and I see why it isn't working. Adding the id to the where clause won't work in this way because it doesn't account for the precedence of the position search first. I think it would require a different where clause. I've added a parameter, the first and second parameter values could be set to the same run-time value.
So the next query would be:
SELECT id FROM artworks WHERE position > %s OR (position = %s AND id > %s) ORDER BY position, id LIMIT 1
and the prev query would be:
SELECT id FROM artworks WHERE position < %s OR (position = %s AND id < %s) ORDER BY position DESC, id DESC LIMIT 1
If you want to only display artwork from the same artist then you would have to add another filter to each previous and next recordset so that it filters by the artist field of the first recordset, just like you did with the position. Set a $_GET variable from the first recordset and then add it as a parameter to the other recordsets that way.
