Coupon Code: compare entered value with value from database
Thread begun 5/03/2015 7:55 am by info4753 | Last modified 5/06/2015 9:46 am by Ray Borduin | 2258 views | 4 replies |
info4753
I've applied a coupon code and would like to compare the value that has been entered by the customers via form field (and saved into a session variable) with a value from a database table instead of a manually entered value in the cart definition. Is that possible?
Yes... just filter a recordset with the value saved in the session and then save another session variable with the coupon amount from the returned recordset.
Use the coupon amount variable when defining your cart discount and that should complete the loop so that your coupons can be database driven.
info4753
Thanks Ray.
You mean like this:
On the cart page:
Filter recordset:
$rsEventsAktion = new WA_MySQLi_RS("rsEventsAktion",$db_i,1);
$rsEventsAktion->setQuery("select `events`.`EventAktionCode` AS `GutscheinCode`,`events`.`EventAktionVon` AS `EventAktionVon`,`events`.`EventAktionBis` AS `EventAktionBis`,`events`.`EventTitel` AS `EventTitel` from `events` where (now() between `events`.`EventAktionVon` and `events`.`EventAktionBis`) AND `events`.`EventAktionCode` = ?");
$rsEventsAktion->bindParam("s", "".(isset($_SESSION['GutscheinCode'])?$_SESSION['GutscheinCode']:"") ."", "-1"); //WAQB_Param1
$rsEventsAktion->execute();
Define 2nd Session:
@session_start();
if("" == "") {
$_SESSION["GutscheinCode2"] = "".($rsEventsAktion->getColumnVal("GutscheinCode")) ."";
In the cart definition:
//eCart Rule
function WAEC_eCart_DegustationWeine10() {
$totalDiscount = 0;
if (true && (($this->ConditionalTotal("Quantity", "GutscheinCodeArtikel", "1") > 0) && ((isset($_SESSION['GutscheinCode'])?$_SESSION['GutscheinCode']:"") == "".$_SESSION['GutscheinCode2'] .""))) {
$totalDiscount += ($this->ConditionalTotal("TotalPrice", "GutscheinCodeArtikel", "1") * 0.1);//Result
return WA_eCart_FormatNumber($totalDiscount, $this->ForceDecimalsC, $this->DecimalPlacesC);
//eCart Rule
Can I also use the value of the filtered recordset directly like this?
//eCart Rule
$totalDiscount = 0;
if (true && (($this->ConditionalTotal("Quantity", "GutscheinCodeArtikel", "1") > 0) && ((isset($_SESSION['GutscheinCode'])?$_SESSION['GutscheinCode']:"") == "".($rsEventsAktion->getColumnVal("GutscheinCode")) .""))) {
//eCart Rule
You can't refer to the recordset in the cart rule because the recordset may not be on the page. You should only use the Session variable.
info4753
That worked. Thanks a lot.
I can even use the two sessions to check if the entered code is correct or not.
