How to send a form on page load
Thread begun 5/01/2015 8:11 am by s.joiner74419001 | Last modified 5/11/2015 4:29 pm by Ray Borduin | 7333 views | 20 replies |
s.joiner74419001
I have a success page that the user is directed to from paypal after making a payment from the paypal button on a web page. I need to update the users details in a database with a value of paid which I have tried to do using a form with a hidden element with the value 'paid' the form uses update record behaviour with a trigger of current page submit and javascript like this:
function load()
document.forms["paid"].submit();
But when the page loads it doesn't send the form or update the record.
Help please!
A few things.
1) Just because you define a function called load() doesn't mean it will be called on load.
2) If it was called on load the page would be stuck in an infinite loop as the page would submit, re-load, and re-submit indefinitely
3) I don't think you need a form submit or hidden form element at all. Just use the "before page load" trigger in the update record server behavior and set the value to: paid directly from the Server Behavior.
s.joiner74419001
Ok thanks Ray, another issue I have is the user us directed to PayPal after completing a membership form and then directed back to the success page where I want to update the record from. Will the session keep so I can send the value paid to the correct members I'd (session) .. Hope this makes sense!
Yes... you should be using Paypal Express checkout for this to work properly.
s.joiner74419001
Ok Ray. Not sure If I have the ability to do this so where do I start with this. Should I be creating a system with eCart? To explain my required process. the user can visit our website to become members by completing an application form which includes username and password creation. I custom built this form with the help of 'Databridge'. it is on submitting the form, the user is then directed to a confirmation page where there basic details are displayed with the price of membership. It is from here I want the user to be taken to a payment system ( So as you suggested, pp express checkout ). Subsequently the form is sent to a database and in particular a value of 'form complete' is sent to the 'status' column. As I described previously I want this column to be updated to 'Paid' or 'Cancelled' depending on the result of the transaction. The reason I need these values is to secure access to the members area of our web-site to 'Paid' members only. I was previously trying to achieve my goal by using paypal buttons which is probably why I was getting stuck with this.
I have eCart but I am completely lost on Where to go after creating an eCart object and what components I need and how I would use my current application form and database. Plus a lot of the pages created look to be pointing to creating product pages but we provide a service and so need a single option to purchase, therefore add to cart isn't necessary, we just need subscribe. is this easy to customise?
This might require a premium support ticket if so thats fine just say and I will put in a request.
Thanks in advance.
I think the easiest solution would still be to use eCart. You can use an add to cart server behavior, create the view cart page, and run the checkout wizard to complete the checkout process. Since you are only selling one item and don't really need a cart, you can have the add to cart button link directly to the checkout page and never actually view the cart page.
s.joiner74419001
Hi Ray,
I am experiencing a major fault with the checkout wizard as follows:
Firstly I will explain what I am doing.
I first apply the add to cart server behaviour to my application form page using the submit form button as the trigger. in the behaviour I re-direct to the view-cart page ( memb-payment.php). On this page I used the Display manager to add the cart display and then add a checkout button. I then open the checkout wizard and complete the settings. ( using sandbox API credentials ). After completion I proceed to click 'Finish' and this is where the issue happens.
It creates all there numerous pages, but extra untitled pages, and then crashes as shown on attachment.
The following pages are created:
Untitled-1.php - This appears to be the order confirmation page.
Untitled-2.php - Blank html document
Untitled-3.php - This appears to be the checkout form.
confirm.php - Blank html document
confirm_cart.php - Blank html document
checkout.php - Blank html document
checkout_failure.php - Appears to be complete
checkout_success.php - Appears to be complete
Please help.
You're probably aware that I am in the UK and so its difficult to get the support from yourselves when required because of the time delay. We are desperate to get this up and running asap. my laptop is currently at fault so I will be taking my office iMac home so we can hopefully get this resolved this evening.
Thanks in advance.
Try clearing the cache .dat file and running the wizard again.
Also if you get a message while running the wizard that says "This file has been edited outside of Dreamweaver would you like to reload" make sure to click "no".
If you continue to have this problem, please post Skype contact information and we can try to come in early to catch you during business hours later this week to look into it with you.
s.joiner74419001
Hi Ray,
Ive tried deleting the Cache.dat file numerous times but nothing changes. Ive re-installed and still no joy. Are you able to trouble sheet this evening? (I'm 5 hours ahead i think )
Skype name in PM
s.joiner74419001
Hi Ray.
I'm in office until 4:30pm BST (11:30am EST) and would be great if we could try and solve issue either before this time or some time this evening, any time from about 8:00pm BST (3:00pm EST )
