What is the difference between forms builder and contact and/or registration solution
Thread begun 8/30/2009 1:20 pm by jhmblvd | Last modified 9/02/2009 12:43 pm by Ray Borduin | 3177 views | 3 replies |
jhmblvd
What is the difference between the three products? (Forms Builder, Registration and Contact Solutions) I purchased "Forms Builder" to build forms, but it looks like you need to know PHP and have a dynamic site, etc. Should I have looked at these products instead.
Form builder is a Dreamweaver tool you can use to create as many forms as you want to do whatever you want.
Registration Solution is a completed site created using our tools that allows user registration and login and includes the contact solution.
The Contact Solution is a single page form that sends an email. It is similar to what you could produce using form Builder and Universal Email.
The difference is like the difference between buying a home and buying all of the materials and machinary used to build one. If you a happy with a pre-fabricated model then it is good to go with a solution. If you want to do a lot of customization you would want to have the tools used to create it.
jhmblvd
What is the difference between products
Thanks for the information. If I have a website and wanted to add a registration area? Could I use the Registration Solution?
Yes, you would probably want to update the template and links to integrate with your site, but you could use the registration solution as a starting point and it would be all functional.
