How to change text colour of PHP echo depending on value
Thread begun 4/29/2015 8:38 am by s.joiner74419001 | Last modified 11/25/2020 12:10 pm by Ray Borduin | 3261 views | 5 replies |
s.joiner74419001
I have an html table displaying data from a database and on a particular column I would like to change the text or cell colour depending on its value
the values in the DB table column are 'Active' 'On hold' 'Closed'
Help please!
You can add a conditional css attribute with php like:
<div class="<?php echo($row_Recordset1['status']=='Active'?'activeClass':''); ?><?php echo($row_Recordset1['status']=='On hold'?'holdClass':''); ?><?php echo($row_Recordset1['status']=='Closed'?'closedClass':''); ?>">here is my text</div>
This way you will have three classes assigned to the text based on the value in that column and those three classes can have different styles including color.
s.joiner74419001
Just tried this.. exactly what I needed. Thanks once again Ray!
s.joiner74419001
Hi Ray.
How can I achieve something similar to this, but PHP value would be something like..
<?php echo($rsActiveApps->getColumnVal("rtm_status")>17 and $rsActiveApps->getColumnVal("rtm_status")< 35 ?'legalClass':''); ?>
So if the column value is between 18 and 34 the ‘legalClass is used.
Hope this makes sense.
Thanks in advance.
class="<?php echo(($rsActiveApps->getColumnVal("rtm_status")>=17 && $rsActiveApps->getColumnVal("rtm_status")<=35)?'legalClass':''); ?>"
s.joiner74419001
Top Man!! Thanks Ray!
