fckeditor.js
Thread begun 4/29/2015 4:57 am by neilo | Last modified 4/30/2015 6:47 pm by Ray Borduin | 3855 views | 7 replies |
neilo
fckeditor.js
From Hosting Providers:
"We have detected that you have a vulnerable version of the 'Fckeditor' script in your webspace. This version is vulnerable to attack by third-parties and will allow them to install their own code in your webspace. This will cause your content to be damaged, allow them to infect the computers of visitors to your website, and in extreme circumstances allow the server itself to be compromised.
This is the file that was detected, this should help you find the script location (it might be part of another plugin or script):
../cms/HTMLEditor/fckeditor.js
This is a *very* serious vulnerability and needs to be dealt with as soon as possible. Inaction may result in your site being taken offline unless we hear from you. "
Advice needed please. [Easy if possible]
I attach copy of the fckeditor.js script
Upgrade to CKeditor from the latest version of DataBridge and delete the old CKeditor folder entirely. We moved to CKeditor many years ago and it shouldn't have the same vulnerabilities the old version did.
neilo
Databridge Folder to PCMS
How to extract new folder (from Databridge) in order to replace old PCMS folder? Which PCMS folder? See attached PCMS folder tree. Do I rename old folder/files? Need step by step.
Is this an old powerCMS v1 site? Or is this just a site you created using HTMLEditor? The easiest solution is probably to delete the entire HTMLEditor folder and then replace the editors on the pages where they are used.
neilo
It's an old PowerCMS v1 or v2 install, so the HTML Editor instances are part of that? So they would all be in cms/admin/contents_update.php?
neilo
Yes?
Please - hosting servers to close/delete site imminently.
Yes... delete the old CKeditor folder immediately and the security hole will be closed.
Then you will go to the contents_update.php page to add the newer CKeditor and you should be good to go.
Another option if you have Design Extender is to (save a backup first) delete the entire admin for the cms and the connection for it and then have Design Extender upgrade the entire back end to the newest version.
neilo
Huge thanks, Ray.
