Javascript Error
Thread begun 4/28/2015 6:20 am by s.joiner74419001 | Last modified 5/27/2015 11:04 am by Ray Borduin | 3668 views | 5 replies |
s.joiner74419001
Javascript Error
I am getting this error message when opening or going to pages:
While executing findConnection in WADYN_CONN.htm, a Javascript error occured.
I assumed that it was connected to my DATABASE connection which is not appearing in the DATABASE window.
I have re-created the DB connection file using DW MySql connection and it now seems OK.
I then tried to create connection file using WA Dynamic SQL connection and I get the attached error message.
So there seems to be an issue with WA DB connection feature.
This appears to be a cache issue. If you close Dreamweaver, delete the winfilecache .dat file in your Dreamweaver user configuration folder, then restart Dreamweaver this error should go away.
s.joiner74419001
Hi Ray, that file wasn't in the config folder. But I mangled to sort it be re-installing DW and plugins.
Thanks!
s.joiner74419001
Hi Ray,
I'm still getting this Javascript error when opening a new file from a template. Ive tried deleting the macfilecache.dat file in the config folder but it does not solve the issue. (incidentally this file on a mac is located through this file path - hold down the alt key and select go from the top finder menu, then go to - library / Application support / Adobe / Dreamweaver / macfilecache.dat )
Any ideas?
Please contact me via skype and I'll set up a screen sharing session to look into this with you.
s.joiner74419001
Hi Ray. this will have to wait as I am away for two weeks from tomorrow. Will contact you via Skype on my return.
Thanks!
