Disable inline editing globally
Thread began 4/28/2015 6:14 am by CraigR | Last modified 4/30/2015 3:47 pm by Ray Borduin | 992 views | 3 replies |
CraigRBeta Tester
I can disable inline editing by setting the fifth parameter to true on calling any particular instance of WA_getCMSContent(...)
What I want to do is disable inline editing across the whole site,
I have tried changing the default value of the function in WA_CMS.php - which works, but the js tab at the bottom of the page still appears.
Can you advise the best way of removing the tab when I disable inline editing please?
You could probably just add CSS to make the tab have display:none... It shouldn't matter if it was there as long as nobody can see it.
CraigRBeta Tester
Thanks Ray,
Easy to do, just wondered if I was missing something else when changing the global setting
I don't think so. It looks like that is automatically added for admin. I forget exactly how it works, so that was just an easy solution.
I think it stores the value as a variable: WAPCMS_HIDDEN
You could probably find where that is written to the page and just remove it entirely.
