Security Assist
Security Assist - Allow for Admin to first approval users - How do I do that
Add another field to your users table: UserApproved.... Give it a default value of 0 and then in the admin back end allow the admin to update that field with a checkbox.
Then on the login page update the Authenticate User server behavior to store the UserApproved value in the session.
Finally update your logged in rule to make sure it checks the saved session variable and blocks users that haven't been approved.
Thanks for that Ray - I will try that, that`s not a reflection on your advice but on my ability!
I have tried but failed - would appriciate step by step insructions
I have the three steps listed above. What step are you getting stuck on? What have you tried? What is happening on the page when it doesn't work?
