Checkout button not redirecting
Thread begun 8/30/2009 7:56 am by jamie325853 | Last modified 9/28/2009 2:16 pm by Jason Byrnes | 2798 views | 4 replies |
jamie325853
Hi hopefully someone can spot the problem here Ive started again and done various things but still not working.
I for some reason cant get the checkout button to the checkout.php page from cart
When its pressed it just diverts to viewcart.php?
Ive done numerous tests but still unable to get it to work.
Here is the link: viewcart.php
Please compress a copy of the viewcart.php page into a zip archive and attach it to your reply. I will need to inspect the code on the page to be able to determine what is wrong.
beyondconcepts256352
I am having the same problem, but I don't see what the final solution to this question.
When I click the server behavior and select the redirect page, I save and post, but the redirect does not work. Have tried using internal links and full URL links, neither one will redirect. It seems like there is a java script missing.
I am using eCart 4.5.0.
I am getting tired to trouble shooting this stuff.
office172461
It doesn't look the the original poster ever completed the troubleshooting process so I don't think there was an answer.
You mentioned a problem with Javascript but you didn't include an error message, so the best I can do is suggest clearing the cache:
146/
PHP doesn't let browsers see the underling code so the link won't revel any code problems without error messages.
Also take a look at this article:
10 Tips for getting quick help from a support forum
145/
it is possible that a PHP error is occurring which is causing the redirect redirect to fail. To check add the following at line 1:
error_reporting
(E_ALL);
Please compress your cart display page into a zip file and send it along with your reply so I can look at the code.
