Blank products_detail page
Thread begun 4/24/2015 8:13 am by joerg431091 | Last modified 4/28/2015 12:02 pm by Ray Borduin | 4909 views | 8 replies |
joerg431091
I tried to apply FedEx shipping calculation to an existing eCart object by using the checkout wizard. After finished, the checkout pages had been overwritten with the new version.
Now I have trouble with my products_detail.php page showing completely blank.
I added the error log to the page and get the following error:
Deprecated: mysql_pconnect(): The mysql extension is deprecated and will be removed in the future: use mysqli or PDO instead in /Applications/MAMP/htdocs/XXXXXX/Connections/XXX.php on line 9
Parse error: syntax error, unexpected ';' in /Applications/MAMP/htdocs/XXXXXX/WA_eCart/eCart1_PHP.php on line 120
I then changed the error reporting in the php.ini file of the MAMP folder to:
error_reporting = E_ALL & ~E_DEPRECATED
But I am still getting the same error message. The php.ini file that I changed is the one that is shown in the path of the phpInfo page.
What am I missing? Any thoughts are appreciated.
Thanks a lot,
Joerg
You probably need to remove the error log code you added to the page, since it is overwriting the php ini setting for the page and showing the deprecated message.
In terms of the error that is actually preventing the page from showing that is on the page referenced: WA_eCart/eCart1_PHP.php
and the line referenced: 120
I could look at that line and tell you what is wrong with it if you attached a copy of that page.
joerg431091
Hi Ray,
Thanks for your prompt response.
I will attach a copy of the eCart1_PHP.php page to this post.
The line 120 is: $totalShipping += ;//Result
Thanks again,
Joerg
It looks like there was a flat rate shipping rule applied with a blank value.
Update that line to:
$totalShipping += 0;//Result
That should solve the problem.
joerg431091
Hi Ray,
That took care of it. Thank you very much.
Best,
Joerg
joerg431091
Hi Ray,
A follow up problem if you allow:
I received all testing information from FedEx (Account, Meter, etc) that I included during the setup with the checkout wizard.
I can't see any type of shipping information or option during checkout nor do I see any error messages etc. I could not find any tutorial or information about what I am supposed to see during checkout so am not sure about how to go forward.
I found an older post from Jason to troubleshoot (which was for eCart 5) and did include the following code in the confirm.php page:
@session_start();
     echo "<p>FedEX: <br />";
     echo "Full Request: ".(isset($_SESSION["eCart1_FedEx_FullRequest"])?htmlentities($_SESSION["eCart1_FedEx_FullRequest"]):"n/a")."<br />";
     echo "Full Response: ".(isset($_SESSION["eCart1_FedEx_FullResponse"])?htmlentities($_SESSION["eCart1_FedEx_FullResponse"]):"n/a")."<br /></p>";
but still do not see anything.
Is there a tutorial or any other information available that explains how to include FedEx rate calculation for eCart 6 or can you point me in the right direction about how to do this?
Ultimately I like to present the customer with several shipping options that he/she can choose from.
Thanks again and best regards,
Joerg
The shipping server behavior should be applied on the confirm_cart.php page. The debug code you added should show the posted data, so it implies that the page never tried to get a fedex quote at all. If you provide a copy of the page I can take a look and see if I can spot a problem.
If you gave me a url to reproduce the problem and ftp access I could debug more thoroughly.
joerg431091
Hello Ray,
I will attach the confirm_cart.php page. I unfortunately do not have this online yet as I like to see how this functions before I change the current checkout of the site. But hopefully the page might help.
Thanks so much.
Joerg
It looks like it would work.
Try using this to see the debug information on a different page:
@session_start();
var_dump($_SESSION);
then go through the checkout process until you see the payment fields. At that point you can open up the debug page in a separate window and it should tell you why fed ex is failing.
