Name of variable / response generated when a user tries to log in
Thread begun 4/23/2015 12:12 pm by iain331081 | Last modified 4/24/2015 12:12 pm by Ray Borduin | 7937 views | 12 replies |
iain331081
This is a bit of a random one, but I have been looking at creating an app where users can register and login using the same database backend that exists for a website. I have the registration working where a new record is successfully created in the DB when someone registers in the app.
But I haven't quite got the login to work - I'm using some JS request to grab the response of the login check - am I right in thinking if the login is successful the response to look for would be 'Log in success'?
I'm just getting that from the line:
<?php if(WA_Auth_RulePasses("Log in success")){ // Begin Show Region ?>
in the login page.
Hope that makes some sense, and I'm barking up the right tree, although its confused further by some reference to JSON which I'm not really familiar with, and don't think there is any JSON on the log in web page.
Thanks for any pointers - but I think all I need to confirm is the correct value of any response for a successful login.
iain331081
More info below.
This page won't have a response on success or failure. You would have to check the webassist/security_assist/helpergroupsrulesphp.php file to see the correct rule name to use, but probably you would remove all of this from the bottom of the page:
<?php if(WA_Auth_RulePasses("Validated form")){ // Begin Show Region ?>
<p><span class="loginfail">Invalid username or password - please try again.</span></p>
<?php // End Show Region ?>
<p>You have been logged in</p>
<?php if(WA_Auth_RulePasses("Failed log in")){ // Begin Show Region ?>
<?php if(WA_Auth_RulePasses("Emailed Password")){ // Begin Show Region ?>
<p>Password information emailed, please check your inbox</p>
<?php if(WA_Auth_RulePasses("Successful update")){ // Begin Show Region ?>
<p>Registration completed successfully, please log in to access the site</p>
and instead add something like:
<?php if(WA_Auth_RulePasses("Logged In To trade_users_app_temp")){ // Begin Show Region ?>Log in success<?php // End Show Region ?>
iain331081
Thanks Ray - to be honest all of that can probably go from that page - it's only still there for my reference.
All I really know is that the http request back in the app needs some response from the web server to let it know whether the login was successful or not. Will have a look in that other helpergroupsrulesrulesphp.php file, but I might come back to you.
iain331081
OK - looking in there there are two rules - logged in, and logged in to trade_users. (I can use the original trade_users table to test logging in.)
They look like:
case "Log in success":
$comparisons[0] = array(TRUE"".((isset($_GET['loggedIn']))?$_GET['loggedIn']:"")  .""2"");
            break;
and
case "Logged in to trade_users":
$comparisons[0] = array(TRUE"".((isset($_SESSION['SecurityAssist_UserID']))?$_SESSION['SecurityAssist_UserID']:"")  .""2"");
            break;
But not sure what or how to pass anything back to the app side.
Putting this on the page should do it:
<?php if(WA_Auth_RulePasses("Logged in to trade_users")){ // Begin Show Region ?>Log in success<?php // End Show Region ?>
This will return the text between the begin and end region code.
Just make sure you don't have any blank lines in your code and it should work with your app code above.
iain331081
Thanks Ray - can't seem to get it to work.
So on the app side I have a login form with two text fields, UsernameInput and PasswordInput in this JS expression:
var Log_In_group_Username = UsernameInput
var Log_In_group_Password = PasswordInput
var result = Request.post('http://www.miradatravelmedia.com/GSG_App/login.php', { Log_In_group_Username: Log_In_group_Username, Log_In_group_Password: Log_In_group_Password })
function done(response) {
if (response === 'Log in success') {
Event.trigger('loginSuccess');
} else {
Event.trigger('loginFail');
So that should be passing the entered values to login.php on the web server.
And WA PHP in that login.php page below:
Looks like it would be right to me.
What if you just add: <?php echo("Log in success"); ?>
That would presumably bypass the login and respond as if everyone successfully logged in. That could help you narrow down whether it is an issue with the app or the web page.
iain331081
Thanks Ray - that makes sense. I added that and nothing is happening on the app side.
So I guess that suggests the issue is with the JS on the app side.
I get that:
Request.post("http://www.miradatravelmedia.com/GSG_App/login.php", { Log_In_group_Username: Log_In_group_Username, Log_In_group_Password: Log_In_group_Password })
Should send the variables:
to the web server.
And they should be picked up in the line:
"columnValues" => explode($WA_Auth_Separator,"".((isset($_POST["Log_In_group_Username"]))?$_POST["Log_In_group_Username"]:"")  ."".$WA_Auth_Separator."".((isset($_POST["Log_In_group_Password"]))?$_POST["Log_In_group_Password"]:"")  .""), ?php>
And I follow that
} else {
Should pick up whatever is output on the web server and then do one of two things, depending in what it is.
But not so sure what the var result = is doing?
I'm not sure how it is supposed to know to call the done function... Is this just regular javascript trying to use AJAX? I'm pretty sure your php page is good now. It is now a matter of debugging your app code.
Keep the echo statement outside of any IF statements and you will know the issue isn't with what form elements or values are being posted it is simply getting the result from the page.
