Want results page to not show any records when Search submit is pressed
Thread begun 4/23/2015 12:00 pm by JBWebWorks | Last modified 4/23/2015 6:39 pm by Ray Borduin | 3978 views | 8 replies |
JBWebWorks
My Code on results page
<?php require_once('Connections/connpco1.php'); ?>
require_once("webassist/database_management/wada_search.php"); ?>
//WA Database Search (Copyright 2005, WebAssist.com)
//Recordset: WADAplayer_info;
//Searchpage: ;
//Form: ;
$WADbSearch1_DefaultWhere "0!=0";
if (!
session_id()) session_start();
if (isset(
$_POST["search1"]) || isset($_POST["search1"])) {
$WADbSearch1 = new FilterDef;
$WADbSearch1->initializeQueryBuilder("MYSQL","1");
//keyword array declarations
  //comparison list additions
$WADbSearch1->addComparison("sponsor_DONOR","".((isset($_POST["sponsor1"]))?$_POST["sponsor1"]:"")  ."","AND","Includes",0);
$WADbSearch1->addComparison("player_1_name","".((isset($_POST["player1"]))?$_POST["player1"]:"")  ."","AND","Includes",0);
$WADbSearch1->addComparison("player_2_name","".((isset($_POST["player2"]))?$_POST["player2"]:"")  ."","AND","Includes",0);
$WADbSearch1->addComparison("entrydate","2015/03/01","AND",">=",2);
//save the query in a session variable
if (== 1) {
$_SESSION["WADbSearch1_Registered_Players_Information"]=$WADbSearch1->whereClause;
else     {
//get the filter definition from a session variable
if (== 1)     {
    if (isset(
$_SESSION["WADbSearch1_Registered_Players_Information"]) && $_SESSION["WADbSearch1_Registered_Players_Information"] != "")     {
$WADbSearch1->whereClause $_SESSION["WADbSearch1_Registered_Players_Information"];
    else     {
$WADbSearch1->whereClause $WADbSearch1_DefaultWhere;
  else     {
$WADbSearch1->whereClause str_replace("\\''""''"$WADbSearch1->whereClause);
$WADbSearch1whereClause '';
if (!function_exists("GetSQLValueString")) {
function
GetSQLValueString($theValue$theType$theDefinedValue ""$theNotDefinedValue ""
  if (
PHP_VERSION 6) {
$theValue get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;
$theValue function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue);
  switch (
$theType) {
    case
"text":
$theValue = ($theValue != "") ? "'" $theValue "'" "NULL";
      break;
    case
"long":
    case
"int":
$theValue = ($theValue != "") ? intval($theValue) : "NULL";
      break;
    case
"double":
$theValue = ($theValue != "") ? doubleval($theValue) : "NULL";
      break;
    case
"date":
      break;
    case
"defined":
$theValue = ($theValue != "") ? $theDefinedValue $theNotDefinedValue;
      break;
  return
$theValue;
$currentPage
$_SERVER["PHP_SELF"];
$maxRows_WADAplayer_info
10;
$pageNum_WADAplayer_info 0;
if (isset(
$_GET['pageNum_WADAplayer_info'])) {
$pageNum_WADAplayer_info $_GET['pageNum_WADAplayer_info'];
$startRow_WADAplayer_info $pageNum_WADAplayer_info $maxRows_WADAplayer_info;
mysql_select_db($database_connpco1$connpco1);
$query_WADAplayer_info "SELECT ID, sponsor_DONOR, player_1_name, player_2_name, player_1_address, player_2_address, player_1_city, player_2_city, player_1_zip, player_2_zip, player_1_phone, player_2_phone, player_1_email, player_2_email, player_1_hdcp, player_2_hdcp, first_day_am_pm, second_day_am_pm FROM player_info";
setQueryBuilderSource($query_WADAplayer_info,$WADbSearch1,false);
$query_limit_WADAplayer_info sprintf("%s LIMIT %d, %d"$query_WADAplayer_info$startRow_WADAplayer_info$maxRows_WADAplayer_info);
$WADAplayer_info mysql_query($query_limit_WADAplayer_info$connpco1) or die(mysql_error());
$row_WADAplayer_info mysql_fetch_assoc($WADAplayer_info);
if (isset(
$_GET['totalRows_WADAplayer_info'])) {
$totalRows_WADAplayer_info $_GET['totalRows_WADAplayer_info'];
} else {
$all_WADAplayer_info mysql_query($query_WADAplayer_info$connpco1);
$totalRows_WADAplayer_info mysql_num_rows($all_WADAplayer_info);
$totalPages_WADAplayer_info ceil($totalRows_WADAplayer_info/$maxRows_WADAplayer_info)-1;
$queryString_WADAplayer_info
if (!empty(
$_SERVER['QUERY_STRING'])) {
$params explode("&"$_SERVER['QUERY_STRING']);
$newParams = array();
  foreach (
$params as $param) {
    if (
stristr($param"pageNum_WADAplayer_info") == false &&
stristr($param"totalRows_WADAplayer_info") == false) {
array_push($newParams$param);
  if (
count($newParams) != 0) {
$queryString_WADAplayer_info "&" htmlentities(implode("&"$newParams));
$queryString_WADAplayer_info sprintf("&totalRows_WADAplayer_info=%d%s"$totalRows_WADAplayer_info$queryString_WADAplayer_info);
//WA AltClass Iterator
class WA_AltClassIterator     {
  var
$DisplayIndex;
  var
$DisplayArray;
  function
WA_AltClassIterator($theDisplayArray = array(1)) {
$this->ClassCounter 0;
$this->ClassArray   $theDisplayArray;
  function
getClass($incrementClass)  {
    if (
sizeof($this->ClassArray) == 0) return "";
      if (
$incrementClass) {
      if (
$this->ClassCounter >= sizeof($this->ClassArray)) $this->ClassCounter 0;
$this->ClassCounter++;
    if (
$this->ClassCounter 0)
      return
$this->ClassArray[$this->ClassCounter-1];
    else
      return
$this->ClassArray[0];
//WA Alternating Class
$WARRT_AltClass1 = new WA_AltClassIterator(explode("|""|WADAResultsRowDark"));
You mean when submit is pressed without filling any field values in? It looks like that would work with the current code.
Do you have a URL where I can see the problem? I may need FTP access to debug it as well.
JBWebWorks
http://www.pcogolf.org/Registered_Players_Search.php
have only two records as of now for testing. When Search button is pressed it shows both records. I would rather it not show any records.
thanks,
Jim Balthrop
I think just add this before the recordset code after the search code:
if (!$WADbSearch1->whereClause) $WADbSearch1->whereClause = $WADbSearch1_DefaultWhere;
JBWebWorks
Ray,
I added that line as
if (1 == 1)     {
    if (isset($_SESSION["WADbSearch1_Registered_Players_Information"]) && $_SESSION["WADbSearch1_Registered_Players_Information"] != "")     {
      $WADbSearch1->whereClause = $_SESSION["WADbSearch1_Registered_Players_Information"];
    else     {
  else     {
$WADbSearch1->whereClause = str_replace("\\''", "''", $WADbSearch1->whereClause);
$WADbSearch1whereClause = '';
Still shows all records when the search button is pressed?
Seems like that would work... can you give me FTP access so I can debug it?
JBWebWorks
Ray see PM
I see... this didn't work because you had hard coded a date search into the Database Search server behavior, so technically there was always a search being performed.
I fixed the problem by adding the date search directly to the where clause and removing it from the list of comparisons for DataAssist Search. This fixed the problem.
JBWebWorks
GREAT!
Thanks Ray for your help.
