Map not displaying correctly
Thread begun 4/23/2015 11:00 am by les179372 | Last modified 4/24/2015 11:35 am by Ray Borduin | 2473 views | 3 replies |
les179372
I have been trying to display google maps on my website but cannot seem to get it displayed correctly. Could you review www.wedcars4u.com/draft/
any help would be appreciated.
Les
This is because you have the map div inside another div with style="display:none"... The google maps can't position properly with display none... A solution I've found for rendering a map that isn't displayed is to use style="display:block;position:absolute;visibility:hidden" when loading the page and then you can change it back to style="display:none;position:static;visibility:visible" after the map has loaded.
les179372
Hi Ray,
Tried that but still doesn't work. The odd thing is that when I go to street view it displays correctly.
Any ideas?
Les
It doesn't look like you have successfully implemented my suggestion.
I still see the map in a layer with class="hidden" which is defined with display:none; in the css. If you add the map to a visible area as the page loads does it work properly? I still think my original suggestion would work if pulled off properly.
