$CKEditor_initialValue = ""; how to make this the value that was previously entered by the user?
Thread begun 4/23/2015 8:41 am by Nathon Jones Web Design | Last modified 4/29/2015 8:53 am by Ray Borduin | 6041 views | 11 replies |
I would like my HTML Editor field to display the text that was entered by the user should its validation, or other validation on the same page, fail. At the moment it wipes the fields when a validation fails.
I've worked out how to do it for basic input fields, adding value="<?php echo(ValidatedField("newspreview_166","formTEXTINPUT")) ?>"
However the default value for the HTML Editor box is referenced as follows:
I tried adding this:
$CKEditor_initialValue = "<?php echo(ValidatedField("newspreview_166","formTEXTAREAINPUT")) ?>";
But that throws back a syntax error.
Hope you can help, thank you.
NJ
$CKEditor_initialValue = "". (ValidatedField("newspreview_166","formTEXTAREAINPUT")) ."";
"It appears that one of your server-side values is improperly coded. Please check this interface for inconsistencies." ...on save.
Attached. Thank you.
NJ
EDIT: Also, if validation passes, it is saving to database but not moving to the confirm page (newspreview.php).
The interface wants an extra space in that line:
$CKEditor_initialValue = "". (ValidatedField("addnews_166","formFULLTEXT"))  ."";
I can't see what would cause the redirect to not happen. I'd need FTP access to debug it. Usually it is an extra space or line break on the page, but I don't see one here... perhaps in one of the includes? Is there an error message?
There is a bug with the File Manipulation > Upload File and MySQLi Insert behaviours.
When you attempt to bind the Simple Server File Name or Server File Name to your image field, in the MySQLi Insert Record > Column Bindings dialog it inserts invalid code - a random ] - to the $InsertQuery line and even if you fix it manually it reports back with this "It appears that one of your server-side values is improperly coded. Please check this interface for inconsistencies." error.
<sigh>
I've double checked the page, but I'm now getting the following errors at the foot of the form:
Warning: Unknown: open(\\VHOSTS3SHARE01\expressphpsessions$\sess_ueb25kn04i9c9tsgjip77k40s4, O_RDWR) failed: No such file or directory (2) in Unknown on line 0
Warning: Unknown: Failed to write session data (files). Please verify that the current setting of session.save_path is correct (\\VHOSTS3SHARE01\expressphpsessions$) in Unknown on line 0
For this page...
http://www.nathonjones.com/templates/addnewsPHP/admin/addnews.php
I provide FTP details below so you can take a look at it.
Thank you.
NJ
I'm not seeing the improperly encoded message when opening that page or the server behavior for insert on it. What would I have to do to reproduce it?
The code on the page you sent looks perfectly good. The errors you are getting are server configuration issues that have nothing to do with your code.
The error message says:
That is the problem. It looks like you are using a folder with a dollar sign in it as the session save path. That might be the problem... or it could be the permissions on that folder. Either way this is something that you will have to resolve on the server. You may want to open a trouble ticket with your hosting provider to help.
If you provide steps to reproduce the error with the Uploaded file name field then I can look into that one and make sure it gets fixed.
The improperly encoded message has resolved itself following a switch off and switch back on over the weekend, however the server configuration errors remain although I think I have spotted a pattern.
If you go here and click the Add News button:
http://www.nathonjones.com/templates/addnewsPHP/admin/admin.php
You'll get a page with no error message at the foot and you can add a news item (which takes you through to the newspreview.php page).
When you get to newspreview.php it queries our database using the Session ID created by the "Save id in session as:" in the Insert Record behaviour on the previous page and it displays the correct record from the database so that part of it is working.
I have a confirm button on newspreview.php which is a WebAssist MySQLi Update Record behaviour that turns a tinyint field from 1 (True) to 2 (False) on submit. It is when you click this button that the server errors appear and it doesn't write to database.
Questions
1) What should the "Lookup value" be in the General tab of the WebAssist MySQLi Update Record behaviour dialog? I have tried setting it to both the ID field from the recordset on the page and also a hidden form field which is populated by the ID field from the recordset. Neither work
2) In the Update Record behaviour I am only updating the True/False field - should I, even though it's the primary key field, be updating the primary fey field in the database?
I think this error is related to the "Save id in session as:" feature or the WebAssist MySQLi Update Record behaviour. I'm not using any folder with a dollar sign in it as the session save path, as you describe, I am simply using the WebAssist MySQLi Update Record behaviour.
If it is choosing to use a dollar sign somewhere then my host isn't going to be able to help and, indeed, they have already responded with "this is a scripting issue".
Hoping you can help. Thank you.
NJ
EDIT: Sometimes I get this error depending on if I choose the hidden form field or the recordset ID field as the Lookup value for the Update record behaviours;
Notice: Undefined variable: rsNEWNEWS in \\nas44ent\domains\n\nathonjones.com\user\htdocs\templates\addnewsPHP\admin\newspreview.php on line 10
Fatal error: Call to a member function getColumnVal() on a non-object in \\nas44ent\domains\n\nathonjones.com\user\htdocs\templates\addnewsPHP\admin\newspreview.php on line 10
Line 10 is...
$UpdateQuery->addFilter("njnewsID", "=", "i", "".($rsNEWNEWS->getColumnVal("njnewsID")) ."");
Another bug...
So, the WebAssist MySQLi Update Record incorrectly inserts itself BEFORE the recordset even if you've selected to use the recordset as the Lookup value for the ID field.
What is the point of the extensions if you constantly have to battle issues like this?
Half a day wasted on this.
EDIT: Can I log this as a bug? There is clearly something wrong with the way the MySQLi behaviour inserts itself into a page.
The way dreamweaver works, you have to give a weight to each server behavior... and that weight can't change. The weight is a number from 1-100 (recordset's have a weight of 50)... then based on the weight the server behavior is placed on the page.
We have to assign a weight to each server behavior and then DW is supposed to place it accordingly.
When it comes to an insert, there are two possible scenarios. You may want the insert to occur before the recordset... because you might want to display the results that you just inserted on the page. If you put the insert after the recordset, then the results that you inserted wouldn't be displayed because the insert took place after.
Now in your case you are inserting a value from a recordset... so you want the insert to take place after the recordset. We had to make a judgement call to decide which scenario would work by default and which would require moving the code chunk after application to the correct position. Our thoughts were that the first scenario is more common... since most people don't insert from a recordset but many display from one on the same page.. and that the second scenario is a more advanced application, so it is more reasonable that people doing that could figure out that they needed to move the insert below because they are more advanced users.
The reality is that sometimes in Dreamweaver when you need things to happen in a particular order, you need to adjust the order of the code manually. There is no way for us to fix this because it is just the way dreamweaver works. It isn't a bug. It is a limitation in the extensibility model Dreamweaver supports when applying server side code.
If all of the above is the case then why, in your documentation, is there no mention of "weight"? We are left to establish this how exactly? By trial and error because we are "advanced users"? That's quite an assumption.
A simple paragraph explanation in your documentation would have saved me half a day today... "PLEASE NOTE: If you are using the WebAssist MySQLi Update Record behaviour and you are querying from a recordset be sure to check that the Update code hasn't been inserted BEFORE the recordset code otherwise it won't work"
Or is it not included in the documentation because, in effect, you are describing a scenario whereby the extension simply doesn't work without manual coding?
If most people don't insert from a recordset, does that mean that I'm doing something wrong in my approach? Or, if it's least common, what is the most common approach?
The scenario in full...
1) An Insert form adds a new record to our database table and creates a session value which is the unique ID for that record.
2) The Insert form also inserts a value of "True" (1) to a tinyint field in the same database table. That field represents "hide from display" - the 1 (true) value means that it should not be displayed on the public side of the website.
3) Upon submit, the Insert form inserts to database and re-directs to a confirmation page.
4) We use the session value described in step 1 above to query the database table on our confirmation page in order to create a recordset from which we display the newly added record's data.
5) We use an Update form on the confirmation page to change the tinyint field value, as described in step 2 above, to False (2) = the 2 value means that it SHOULD be displayed on the public side of the website.
Whilst I grasp what you're saying you seem to be withholding information about the extensions functionality, particularly in the documentation, that would be of huge help to "advanced users" like myself AND would save you heaps of time responding to the same old "it's not working" support whines on this forum, by e-mail etc. ;)
I find the approach quite odd in its nature.
