Security Assist Hangs when Accessing MySQL Database
Thread begun 8/30/2009 6:51 am by Daryl | Last modified 9/04/2009 1:38 pm by Jason Byrnes | 6119 views | 9 replies |
DarylBeta Tester
I am unable to run SA because the wizard hangs whilst trying to connect to the database between step 1 and 2.
My only option is to shutdown DW via the Task Manager.
I have tested the connection to the db which works with no problem.
I have deleted the winfilecache .dat file which didn't help either.
Any Ideas?
DarylBeta Tester
I have tried recreating the connection although the connection file ended up being the same anyway.
I tried opening DA to see if the same would happen when it tried to access the database - it froze then too.
I tried using SA on a different DB on a different server and everything worked with no problems.
DarylBeta Tester
I have spoken to my tech support, they have said that that they do not block access to Databases and therefore I should not have any problems.
They have checked remote access to my Database and have connected to it.
No surprise as I can connect to it from Dreamweaver, just not from a Webassist Extension.
You will need to use another FTP Program for this, Dreamweaver will not let you access the file, but:
On the Remote Server, open the Connections folder and delete the "mmServerScripts" folder.
DarylBeta Tester
Hi Jason
I logged on to my server, deleted the folder as suggested and just for good measure deleted the cache file which also sometimes helps, but unfortunately the situation has not been resolved.
Any other ideas?
I will need to look into this with you. I have created a technical support ticket so we can look into this issue further.
To view and edit your support ticket, log into your Support history:
DarylBeta Tester
Hi Jason
I can't see a support ticket..
Sorry about that, I will create it again.
DarylBeta Tester
Thanks Jason
I have not seen you respond to your ticket yet.
