problem with HTML Editor
when i can update the content on my database, the text doesnt apper on the html editor, can you helpme
What is the username and password you are using to log in? What are the steps to reproduce the problem?
i removed the login
http://laporteriadesucomunidad.es/admin/web-contenido/index.php
http://laporteriadesucomunidad.es/admin/web-contenido/web-actualizar.php?secID=1
http://laporteriadesucomunidad.es/admin/web-contenido/web-actualizar.php?secID=2
the text it is showing in the page:
http://laporteriadesucomunidad.es/seguros/
http://laporteriadesucomunidad.es/quienes-somos/
It appears to be a charset issue. What charset are you using in the database?
I was able to fix the problem by transforming the text to utf-8 in the code manually. I overwrote the file: /webassist/ckeditor/ckeditor_php5.php in order to fix the problem. I also saved a backup with my changes as: ckeditor_php5_bak.php in case it gets overwritten at some point.
You could have probably also fixed the problem by changing your database charset to utf-8.
