Order ID
Thread begun 4/18/2015 3:11 am by NWak04030229 | Last modified 4/22/2015 10:56 am by Ray Borduin | 3140 views | 5 replies |
NWak04030229
Order ID
Thank you for all your help so far with bits and pieces - am almost there!
One final (I think) question:
How do I change the Order ID? It is set to use the sessionID at the minute and that is much too long a number if anyone has a query. I have looked on the forums and tried to follow some of the answers but I keep getting lost somewhere along the line.
Nick
If you are storing the order in the database then the "Store Cart Summary in Database" server behavior has a "Save As" value that specifies the Session variable name that stores the OrderID from the database. This will be a much smaller number and can be replaced in the receipt pages and email.
NWak04030229
Ray, thanks for the reply. Sorry, I should have mentioned I am not using a database. Is there a way to change it when not using the database?
What do you want to change it to? You can change it, but I'm not sure what you would use.
NWak04030229
Ray - thanks for getting back.
I really just want to make it a bit simpler - at the minute it's about 13 digits/letters long and wanted to simplify it down to maybe 7 or 8
You could pair it down to just the last 7 characters of the same number. Instead of
<?php echo(session_id()); ?>
you could use:
<?php echo(substr(session_id(),-7)); ?>
That would get you just the last 7 characters of that same string. It wouldn't be guaranteed unique, but probably close enough.
