a bit more mysql to mysqli
Thread begun 4/17/2015 11:27 am by Jamie | Last modified 4/21/2015 10:37 am by Ray Borduin | 3077 views | 5 replies |
Jamie
Hey Ray
Just trying to convert the last bit of the mysql product options to mysqli as the site I am working on now is using mysqli and there is obviously code mismatch as originally we put the options element in using mysql.
In the attached product detail page, the RS on lines 81 - 94 am not sure how to convert to mysqli so that I am able to successfully pass the item option in the ard to cart lines 125 -152
Also, on line 143 should it be
$ATC_itemOptions = "".$AddOption  ."";// column binding
or
$ATC_itemOptions = "".($AddOption->getColumnVal("OptionGroupID"))  ."";// column binding
if you could give me a steer I would appreciate it
many thanks
Jamie
The first one should be correct, but there are other things on the page that have issues that would cause it to not work.
The code that is supposed to be building the $AddOption value is based on a form element on the page named "ProdOptions". I don't see that form element on the page at all right now.
Jamie
ooops gotcha. have now added that but am getting the following error when adding to cart:
array(1) { [0]=> string(2) "14" }
Warning: mysql_real_escape_string(): Access denied for user 'natsssss'@'localhost' (using password: NO) in /home/natsssss/public_html/product-s.php on line 19
Warning: mysql_real_escape_string(): A link to the server could not be established in /home/natsssss/public_html/product-s.php on line 19
Warning: mysql_query() expects parameter 2 to be resource, object given in /home/natsssss/public_html/product-s.php on line 87
The problem is that the custom code from lines 81-94 hasn't been updated to mysqli and is still referring to mysql that no longer has a connection available. I think those lines need to be updated.
Try:
$AddOption
$AddOptionPrice 0
if (isset(
$_POST['ProdOptions'])) {
  for (
$x=0$x<sizeof($_POST['ProdOptions']); $x++) {
$ProductOptionsSelected = new WA_MySQLi_RS("OptionGroups",$DBConnection,0);
$ProductOptionsSelected->setQuery("SELECT * FROM optiongroups INNER JOIN options on options.OptionGroupID = optiongroups.OptionGroupID WHERE optiongroups.OptionGroupID = ? AND OptionID = ?");
$ProductOptionsSelected->bindParam("i""".$_POST['ProdOptions'][$x]  ."""-1");
$ProductOptionsSelected->bindParam("i""".$_POST['Option_'$_POST['ProdOptions'][$x]]  ."""-1");
    if (
$x>0$AddOption .= "; "
$AddOption .= $ProductOptionsSelected->getColumnVal("OptionGroupName") .": " .$ProductOptionsSelected->getColumnVal("OptionName");
$AddOptionPrice += $ProductOptionsSelected->getColumnVal("OptionPrice");
Jamie
Thanks Ray
Now its not passing the option or option value to the cart/checkout pages.
I don't see the problem. I'd have to debug it with you.
