insert into multiple table...
Thread begun 8/30/2009 3:04 am by pejmanfallahi244687 | Last modified 8/31/2009 10:03 am by Jason Byrnes | 1687 views | 1 replies |
pejmanfallahi244687
hi;
i have 3 table related to each other ex,
table 1 : info1 info 2 ....
table 2 : table1id address ....
table 3 : table1id tariff ....
i want to insert into these tables in one transaction.
is there any option that i can insert into these tables in one transaction by dataassist?
You will need to add three Insert Record Server behaviors to the page.
in the first and second Insert Record Server Behaviors, make sure not to set a redirect page.
The first one should insert to the parent table. In the Session Variable section, set the primary key column to create a session variable that can be used in the other two to relate the records.
In the Other Tow Insert Record Server Behaviors, bind the Foreign key Columns to the session variable crated by the first one.
