Submit Button won't work
Thread begun 4/14/2015 9:09 am by Eric Goodman | Last modified 4/15/2015 10:39 am by Ray Borduin | 5495 views | 8 replies |
Eric Goodman
I am starting a new site. Created a form and uploaded it. I can fill out all fields but the submit button does not respond to clicking.
See PM
You have some repeated validation code at the bottom that is probably causing issues. You also have a javascript error in a example.js file that I'm not sure you are using, and it looks like you may be including multiple versions of jquery on the page. All of these things could be contributing to the issues.
If you give me FTP access in the private area of a reply to this thread I can try fixing it for you.
Eric Goodman
see pm
The provided credentials don't seem to be working for me. Please confirm you entered them correctly and that they work for you.
Eric Goodman
sorry, reset password - see pm
This boiled down to a conflict in jquery versions.
You are using a wow slider that needs an older version of jquery and our html5 validation needs a newer version.
I fixed the problem by loading the older version of jquery in the head and then letting the slider load in the body from that, then added the newer version of jquery below where the validation was defined.
That seems to have worked.
Eric Goodman
Submit
That makes sense about the JQUERY with the slider... I tried the form and it's acting a little buggy. The captcha kept failing... I had to re-enter it 5 times... There is also another (the same) form on another page. In fact this form will be on every page of the site I'm doing....
On another page without the WOW slider it doesn't work either. URL listed PM
It seems to be working on that page now, and I've never had a problem with the captcha in my tests. What browser are you using?
Eric Goodman
button
I purchased the latest WOW slider and redid the forms from scratch and everything seems to go no problem now. Thanks for catching the JQUERY issue...
