Open bootstrap modal after add to cart
Thread begun 4/14/2015 5:38 am by info4753 | Last modified 4/15/2015 9:51 am by Ray Borduin | 4540 views | 2 replies |
info4753
I'd like to open a bootstrap modal after a sucessful add to cart from a recordset (and then show up the cart's content). Like this I can open the modal after submit the form:
$('form#addToCart').on('submit', function () {
$('#myModal').modal('show');
return false;
But nothing is added to the cart. Thanks for any help.
The problem is the onsubmit event is actually at the same time as the submit, so the add to cart may not have happened before the modal is opened.
One solution might be to add an iframe into the modal div and submit the form targetting that iframe. That way the cart contents will be refreshed with the submit. Another option would be to use AJAX to submit and re-populate the modal div.
info4753
Thanks for the tip, I'll try to find a solution in this direction.
