Dreamweaver freezes/crashes on testing recordset
Thread begun 4/12/2015 1:16 pm by Clumber Spaniel | Last modified 4/13/2015 12:00 pm by Ray Borduin | 1732 views | 1 replies |
Clumber Spaniel
Hello, I am brand new to these products and have very recently purchased Data Bridge and MYSQLi - I am quite confused enough with the lack of a clear path for learning the software other than many outcome-specific mini tutorials. What's not helping me is that Dreamweaver keeps crashing whenever I try to use MYSQLi extension. Here what causes the crash - and yes, it's repeatable....
1. After setting up my site and server and then creating a mysqli DB connection I then attempt to create a recordset exactly according to the tutorial. (see image attachment 1)
2. I then try to create a filter (as you can see in the screenshot) but when I hit the TEST button I get a MYSQL Error #1064 and then the entire DW app freezes and I have to force quit it.
I have uninstalled all other extensions as a precaution and uninstalled and reinstalled Data Bridge and the MYSQLi extensions and the problem still remains.
I am using Dreamweaver CC 2014 (Creative Cloud subscriber) on Mac Yosemite. Can anybody offer any advice please. Also, if anybody could point me in the direction of a good workflow for the tutorials I would prefer that over the pick-and-mix approach. My only aim si to build non-ecommerce dynamic sites.
Glyn
I've updated the MySQLi Server Behaviors to prevent this error. Please reinstall and you should be able to test your recordset without errors. It appears there is a bug in DW 2014 that causes it to freeze when there is an error in your SQL syntax, and a bug in our extension that case causing an error whenever you use a "contains" filter. I fixed our bug so that it won't error in that case, but if there is an error it will still freeze since that seems to be a DW bug I can't fix... but technically shouldn't happen when using the simple recordset since the interface should prevent bad queries from being written.
