redirecting going wrong
Thread begun 4/10/2015 5:28 am by Jamie | Last modified 4/15/2015 1:26 pm by Ray Borduin | 4837 views | 11 replies |
Jamie
Hey Ray
Am trying to get the attached page to work on a couple of redirects.
1. On the practice_content_results.php page it uses ?ID=practice_1 (or whatever the id is in the db) to identify which shop it is associated with. On this page, if I click delete or update order the action happens but it doesnt redirect back to the correct ?ID=practice_ on either the update order or delete button -
On the update order it redirects to practice_content_results.php without the identifying slug
On the delete it redirects to practice_content_results.php?ID=
2. on the practice_content_update.php page, the update button inserts the entry into the db but doesnt redirect back to the page in item 1. above. The cancel button also does nothing and should redirect to the page in item 1. abaove
Many thanks
Jamie
On the results page you should probably just add a hidden form element to the page to forward the ID.. add it right before the </form> tag on line 591 like:
<input type="hidden" name="ID" id="ResultsID" value="<?php echo($_GET['ID']); ?>" />
Then on the update page do the same thing, but set the value from the recordset like:
<input type="hidden" name="ID" id="ResultsID" value="<?php echo($row_WADApractice_contents['PracticeContentPageID']); ?>" />
Put that one on or near line 295 just before the </form> tag as well.
Jamie
Thanks Ray.
On the results page the delete now works as expected but the update order button there is no change
On the update page, clicking update it hasnt changed what is happening
Looks like it would work to me... please send a current copy of the update page and I'll see if I can spot the problem.
Jamie
here you go. have attached both
jon211112
Looks like there is an extra dollar sign in the hidden form element value... it should be:
Jamie
aha thanks Jon. thats got the _update page working, just need to work out the results page now...
Jamie
still struggling to get the update order function on the attached page to redirect back to itself with the right id in the url
Do you mean Delete? There is no update functionality on this page? Maybe you sent the wrong page?
Jamie
No. It's updating the order of the DB results
