Insert not working Fuel UX Multistep Wizard
Thread begun 4/10/2015 4:23 am by Dave - HHMP | Last modified 4/10/2015 9:53 am by Ray Borduin | 3057 views | 1 replies |
Dave - HHMP
Good afternoon Webassist,
We are having an issue with Data Assist Insert action not being performed in a Fuel UX based Wizard. The Wizard contains more than one form that combine upon Submit.
We use another Extension on occasion (from another provider) and this works fine and Submits the form as expected. We require several fields in this Wizard to be Encrypted upon Submit so for this we are using the Webassist extension, but it fails to Insert any of the form inputs to the Database. We have used this extension many times to Insert so we believe we are using it correctly and know what we are doing in that regard but this is the first time we have used it across a Wizard.
Any advice on how we rectify this issue?
Thanks in advance.
Dave.
It sounds like it is probably an issue with the Trigger setting in the insert server behavior. It is hard to say without looking at the page. If you sent a copy of the page you are working on I could take a look and see if I could spot the exact issue.
