multiple insert from form values
Thread begun 4/07/2015 12:13 pm by Sweens | Last modified 4/09/2015 2:12 pm by Ray Borduin | 3224 views | 4 replies |
Sweens
Hi Jason
I've created a 'poll' page that has nested repeat regions and radio buttons for each answer id.
I've managed to get it so that the form appears to work, in that you can only select one answer to each question - but when submitting the form
1) only one record is added - but the answer id isn't
2) the form displays the following before each question:
Warning: Cannot modify header information - headers already sent by (output started at ...../polls/take-the-poll.php:92) in ...../polls/take-the-poll.php on line 162
Can you spot a quick fix?
Many thanks
Chris
The insert code on line 129-165 definitely has to be moved up on the page... that is the cause of the header error.
Your naming convention with a dynamically named form element is going to prevent the server behavior from working without some hand coding. I'd suggest a premium support ticket to work on this. I'm sure we can get it working in an hour session, but it is beyond the scope of what I can debug and get working remotely.
Sweens
Hi Ray
Thanks - I have requested premier support.
Cheers
Chris
Sweens
Hi Ray
Many thanks for your help.
However, I'm now getting loads of messages from the forum to say I've replied to numerous threads - which I haven't been near!! I think you may have done something when you took my details for payment!
Cheers
Chris S
Yes, sorry about that.
