Powerstore shipping
Thread begun 4/06/2015 4:56 am by SPT | Last modified 4/15/2015 10:58 am by Ray Borduin | 7336 views | 10 replies |
SPT
Powerstore shipping
Hi Jason,
Could you help me figure out what I have set wrong in our Powerstore.
I believe we have a shipping rule problem.
When I hit check out message:
Transaction Not Completed
We're sorry
Your transaction could not be completed due to a problem occurring while calculating shipping.
I will leave login info in private area.
Thanks.
PS Ray is modifying our store at some point. Just so we do not cross wires. :)
SPT
Login info in private area
We have had several people having trouble with USPS rate calculations recently. I know they are moving from RateV3 to RateV4 in September. I'm wondering if new accounts no longer work with RateV3?
I can look into this with the FTP information you provided and let you know if I find a solution.
SPT
Thanks Ray.
SPT
Hi Ray,
Any luck on the USPS shipping? I still can not get it to check out.
SPT
Other concerns:
1 - the Gallery does not work in firefox, safri, or chrome (on the 4 computers here at the office). They seem to work in IE.
Page: https://www.studiotights.com/~studisi5/products_detail.php?ProductID=67
2- Whenever someone visits the site they get a security warning. Do we need an SSl to fix that?
Message:
This server could not prove that it is www.studiotights.com; its security certificate is from *.bluehost.com. This may be caused by a misconfiguration or an attacker intercepting your connection.
3. I have used a Htaccess to change from the stores index page being the default. However people get a warning in their browser about a redirect. Is there a seamless way around this redirect warning?
My htacess code:
RewriteEngine On
RewriteRule ^/?$ /DaCota-Dancewear.php [L,R=301]
1) This had to do with using https:// and not having ssl installed. I did correct this so that it will work anyway now.
2) Yes, you need to install an SSL certificate to not get errors with https:// you will have to talk to your host about getting SSL working
3) Default home page should be set from the hosting control panel and not with .htaccess
4) The shipping isn't working because you are using an invalid API user name... you need to sign up for the api on the usps web site and get a new username to use specifically for this purpose. It is not your normal user name. Use this link to sign up and get the correct user name.https://www.usps.com/business/web-tools-apis/welcome.htm
SPT
Thanks Ray for your patience and fixing this up for us.
So far so good.
Always #1 support from WebAssist!!
SPT
How to get shipping charges with PayPal checkout?
I have the USPS API setup. I have the PayPal API setup. PayPal Express.
When someone goes to check out there is no shipping charge just a PayPal button.
See attachment.
At this point in the process they haven't provided a shipping address, so shipping can't be calculated from USPS yet. Once they go to paypal and fill in their shipping address they will be brought back to your site before payment is approved and the shipping charges should be displayed.
