variable issue within mysqli code
Thread begun 4/04/2015 9:53 pm by software.current355386 | Last modified 4/10/2015 12:06 pm by Ray Borduin | 2204 views | 3 replies |
use a global variablesucessfully to pass screen id around, but cannot seam to use this in mysqli query id
where screenid = $global[pdsscreenid]
Pleasecan someonne tell mewere i am going wrong, thank you
Use a SQL parameter and set it's value instead of adding it to the SQL directly.
tried without success.
have you a crib sheet i could use
or is tehre a better way oof pasig varials aroun
what to be abler to pick up in include filr. plugins and stanrd pages
If you send a copy of the page I can take a look and see if I can spot the error. Do you get an error on the page? You can also try adding:
ini_set
('display_errors',1);
to the top of the page and it may give you more information about what is going wrong.
