MySQli update server behavior not updating record
Thread begun 4/01/2015 7:30 am by stephen287384 | Last modified 4/13/2015 3:31 pm by Ray Borduin | 7996 views | 15 replies |
stephen287384
I have a MySQli update server behavior that is not updating the record but redirects to the correct page after i submit the form. Here is the code:
$rsStores = new WA_MySQLi_RS("rsStores",$PPUconn,1);
$rsStores->setQuery("SELECT * FROM stores WHERE StoreID = ?");
$rsStores->bindParam("i", "".(isset($_GET['StoreID'])?$_GET['StoreID']:"") ."", "-1"); //colname
$rsStores->execute();
if ($_SERVER["REQUEST_METHOD"] == "POST") {
$UpdateQuery = new WA_MySQLi_Query($PPUconn);
$UpdateQuery->Action = "update";
$UpdateQuery->Table = "stores";
$UpdateQuery->bindColumn("StoreName", "s", "".((isset($_POST["StoreName"]))?$_POST["StoreName"]:"") ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("StoreLogo", "s", "".((isset($_POST["StoreLogo"]))?$_POST["StoreLogo"]:"") ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("StoreABN", "s", "".((isset($_POST["StoreABN"]))?$_POST["StoreABN"]:"") ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("StoreAbout", "s", "".((isset($_POST["StoreAbout"]))?$_POST["StoreAbout"]:"") ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("StoreFirstName", "s", "".((isset($_POST["StoreFirstName"]))?$_POST["StoreFirstName"]:"") ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("StoreSurname", "s", "".((isset($_POST["StoreSurname"]))?$_POST["StoreSurname"]:"") ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("StorePhone", "s", "".((isset($_POST["StorePhone"]))?$_POST["StorePhone"]:"") ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("StoreEmail", "s", "".((isset($_POST["StoreEmail"]))?$_POST["StoreEmail"]:"") ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("StoreURL", "s", "".((isset($_POST["StoreURL"]))?$_POST["StoreURL"]:"") ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("StoreAddress", "s", "".((isset($_POST["StoreAddress"]))?$_POST["StoreAddress"]:"") ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("StoreSuburb", "s", "".((isset($_POST["StoreSuburb"]))?$_POST["StoreSuburb"]:"") ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("StorePostcode", "s", "".((isset($_POST["StorePostcode"]))?$_POST["StorePostcode"]:"") ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("StoreTradingMon", "s", "".((isset($_POST["StoreTradingMon"]))?$_POST["StoreTradingMon"]:"") ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("StoreTradingTues", "s", "".((isset($_POST["StoreTradingTues"]))?$_POST["StoreTradingTues"]:"") ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("StoreTradingWed", "s", "".((isset($_POST["StoreTradingWed"]))?$_POST["StoreTradingWed"]:"") ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("StoreTradingThurs", "s", "".((isset($_POST["StoreTradingThurs"]))?$_POST["StoreTradingThurs"]:"") ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("StoreTradingFri", "s", "".((isset($_POST["StoreTradingFri"]))?$_POST["StoreTradingFri"]:"") ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("StoreTradingSat", "s", "".((isset($_POST["StoreTradingSat"]))?$_POST["StoreTradingSat"]:"") ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("StoreTradingSun", "s", "".((isset($_POST["StoreTradingSun"]))?$_POST["StoreTradingSun"]:"") ."", "WA_DEFAULT");
$UpdateQuery->addFilter("StoreID", "=", "i", "".($_GET['StoreID']) ."");
$UpdateQuery->execute();
$UpdateGoTo = "admin_control_panel.php";
if (function_exists("rel2abs")) $UpdateGoTo = $UpdateGoTo?rel2abs($UpdateGoTo,dirname(__FILE__)):"";
$UpdateQuery->redirect($UpdateGoTo);
The results page has a link that passes the StoreID to the update page as a URL variable and the correct record loads but when i submit he form on the update page, it doesn't update but still redirects to the correct page as if it has.
I have also tried this for the lookup value:
$UpdateQuery->addFilter("StoreID", "=", "i", "".($rsStores->getColumnVal("StoreID")) ."");
Are you sure you are passing the url parameter correctly in the form action? I'd have to look at the code to fully debug it. If you post ftp information to a private area of this thread I'll take a look and figure it out.
stephen287384
I'm not passing the url via a form, it's passed by a simple link eg: <a href="store_update.php?StoreID=<?php echo($rsStores->getColumnVal("StoreID")); ?>">View</a> from the store_results.php page.
The store_update.php page then loads the correct store record but won't update it when I submit the form on the store_update.php page.
You need to keep passing it through the form action so that after the submit it can be used in the update. If you can provide a url and ftp access in the private area I can give line numbers and help more directly. What do you have as the form action parameter on the update page?
stephen287384
PM
Change that to:
<form  action="store_update.php?StoreID=<?php echo(intval($_GET["StoreID"])); ?>" name="storeUpdate" id="storeUpdate" method="post">
Then it should work
stephen287384
PM
I had my brackets wrong... please try again I've updated the previous thread.
stephen287384
Yep, that worked, thanks Ray!
Jay1983
Jay329
Hi Ray,
I'm experiencing a similar issue. My database is not updating. Please see below. I'm passing the id from another page via URL. I suspect the issue may be the way the form action is setup. Thank you for your help.
<?php require_once('.php'); ?>
<?php require_once('webassist/mysqli/rsobj.php'); ?>
<?php require_once('webassist/mysqli/queryobj.php'); ?>
$UpdateTicketCount = new WA_MySQLi_RS("UpdateTicketCount",$xxxxxxxxx,1);
$UpdateTicketCount->setQuery("SELECT * FROM TicketCounts WHERE Id = ?");
$UpdateTicketCount->bindParam("i", "".(isset($_GET['Id'])?$_GET['Id']:"") ."", "-1"); //colname
$UpdateTicketCount->execute();
if (isset($_POST['submit']) || isset($_POST["submit_x"])) {
$UpdateQuery = new WA_MySQLi_Query($xxxxxxx);
$UpdateQuery->Table = "TicketCounts";
$UpdateQuery->bindColumn("Artist", "s", "".($UpdateTicketCount->getColumnVal("Artist")) ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("Venue", "s", "".($UpdateTicketCount->getColumnVal("Venue")) ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("ShowDate", "t", "".($UpdateTicketCount->getColumnVal("ShowDate")) ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("TotalSold", "i", "".($UpdateTicketCount->getColumnVal("TotalSold")) ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("PreviousDaySold", "i", "".($UpdateTicketCount->getColumnVal("PreviousDaySold")) ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("Wrap", "i", "".($UpdateTicketCount->getColumnVal("Wrap")) ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("Capacity", "i", "".($UpdateTicketCount->getColumnVal("Capacity")) ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("Open", "i", "".($UpdateTicketCount->getColumnVal("Wrap")) ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("Advance", "s", "".($UpdateTicketCount->getColumnVal("Advance")) ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("Dos", "s", "".($UpdateTicketCount->getColumnVal("Dos")) ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("OnSaleDate", "t", "".($UpdateTicketCount->getColumnVal("OnSaleDate")) ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("TM", "i", "".($UpdateTicketCount->getColumnVal("TM")) ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("Hold", "i", "".($UpdateTicketCount->getColumnVal("Hold")) ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("FanClub", "s", "".($UpdateTicketCount->getColumnVal("FanClub")) ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("Consignment", "i", "".($UpdateTicketCount->getColumnVal("Consignment")) ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("Sold", "i", "".($UpdateTicketCount->getColumnVal("Sold")) ."", "WA_DEFAULT");
$UpdateQuery->addFilter("Id", "=", "i", "".($_GET['Id']) ."");
$UpdateGoTo = "index4.php";
<!doctype html>
<!--[if lt IE 7]> <html class="ie6 oldie"> <![endif]-->
<!--[if IE 7]> <html class="ie7 oldie"> <![endif]-->
<!--[if IE 8]> <html class="ie8 oldie"> <![endif]-->
<!--[if gt IE 8]><!--> <html class="">
<!--<![endif]-->
<head>
<meta charset="UTF-8">
<meta name="viewport" content="width=device-width, initial-scale=1">
<link href="boilerplate.css" rel="stylesheet" type="text/css">
<link href="update.css" rel="stylesheet" type="text/css">
<!--[if lt IE 9]>
<script src="http://html5shiv.googlecode.com/svn/trunk/html5.js"></script>
<![endif]-->
<script src="respond.min.js"></script>
</head>
<body>
<div class="gridContainer clearfix">
<div id="div1" class="fluid">
</div>
<section class="fluid UpdateTable">
<form action="index4.php?StoreID=<?php echo(intval($_GET["Id"])); ?>" name="submit" id="submit" method="post">
<table width="200" border="1">
<tbody>
<tr>
<td>Artist/Band: </td>
<td>
<input value= "<?php echo($UpdateTicketCount->getColumnVal("Artist")); ?>" />
</td>
</tr>
<tr>
<td>Venue: </td>
<td>
<input value= <?php echo($UpdateTicketCount->getColumnVal("Venue")); ?> maxlength="100" />
</td>
</tr>
<tr>
<td>Show Date:</td>
<td>
<input value = <?php echo($UpdateTicketCount->getColumnVal("ShowDate")); ?> /> </td>
</tr>
<tr>
<td>Total Sold:</td>
<td>
<input value = <?php echo($UpdateTicketCount->getColumnVal("TotalSold")); ?> />
</td>
</tr>
<tr>
<td>&nbsp;</td>
<td>&nbsp;</td>
</tr>
<tr>
<td>&nbsp;</td>
<td>&nbsp;</td>
</tr>
<tr>
<td>&nbsp;</td>
<td>&nbsp;</td>
</tr>
<tr>
<td>&nbsp;</td>
<td>&nbsp;</td>
</tr>
<tr>
<td>&nbsp;</td>
<td>&nbsp;</td>
</tr>
<tr>
<td>&nbsp;</td>
<td>&nbsp;</td>
</tr>
<tr>
<td>&nbsp;</td>
<td>&nbsp;</td>
</tr>
<tr>
<td>&nbsp;</td>
<td>&nbsp;</td>
</tr>
<tr>
<td>&nbsp;</td>
<td>&nbsp;</td>
</tr>
<tr>
<td>&nbsp;</td>
<td>&nbsp;</td>
</tr>
<tr>
<td>&nbsp;</td>
<td>&nbsp;</td>
</tr>
<tr>
<td>&nbsp;</td>
<td>&nbsp;</td>
</tr>
</tbody>
</table>
<input type = "hidden" name ="Id" value = "<?php echo($UpdateTicketCount->getColumnVal('Id')); ?>" />
<input name="submit" type="submit" id="submit" value="Update Record">
</form>
