ecart checkout and continue buttons
Thread begun 3/30/2015 12:43 pm by Jamie | Last modified 6/25/2015 11:50 am by Ray Borduin | 10253 views | 41 replies |
Jamie
Hey Jason
Ran the ecart wizard on a site earlier today and have been trying to get the 'continue shopping' and 'checkout' buttons working but they just redirect to the page that they are on. Have attached the cart.php page and the link to the live page is in the PM section
cheers
Jamie
move this code block form line 73 - 80:
// WA eCart Redirect
if ($natashaCart->redirStr != "") {
if (function_exists("rel2abs")) $natashaCart->redirStr = rel2abs($natashaCart->redirStr,dirname(__FILE__));
header("Location: ".$natashaCart->redirStr);
die();
so that it is just before the doctype tag.
Jamie
got it - perfect thanks
on the same ecart installation, the checkout.php page (which i havent changed from the intial wizard run) is erroring and if you view source the error is
<input id="Company_Name" name="Company_Name" type="text" value="<br />
<b>Fatal error</b>: Call to undefined function WA_coalesce() in <b>/home/natashrb/public_html/checkout.php</b> on line <b>34</b><br />
why would that have been created like that in the wizard?
send a copy of the checkout page please
Jamie
here you go
looks like you may have a bad installation of eCart. all of the code that should be above the doc the tag is missing from the checkout page.
rename the users configuration folder, then open DW to recreate it, then open the extension manger, remove all the extensions and re install them.
after reinstalling the extensions, delete the existing checkout pages and rerun the checkout wizard.
Jamie
Thanks Jason Thats worked fine.
On the checkout page, when I click 'confirm' it opens up the wrong address
instead of
https://www.paypal.com/checkoutnow?token
it opens up
http://www.domainname.com/https://www.paypal.com/checkoutnow?token
Have tried adjusting the PP_ECO_PHP.php page but no joy with that. What do I need to change to get the right path used please?
UPDATE: now the page redirects to the checkout_failure page.....
on the failure page, add the following code to write the session contents:
<pre><?php @session_start(); var_dump($_SESSION); ?></pre>
the session contents will contain the response from the gateway with details on why the transaction is failing.
Jamie
hmmm its not redirecting the the failure page now.....
its back to trying to take me to http://www.domainname.com/https://www.paypal.com/checkoutnow?token
