NY Shipping Rule Not Working
Thread begun 3/27/2015 2:25 am by sfranzken73972 | Last modified 4/08/2015 10:45 am by Ray Borduin | 6086 views | 15 replies |
sfranzken73972
Hi I have created a shipping rule to charge tax in only NY
However when on the checkout page after filling out a NY address it does not work.
My session variable is named svstate; this is on the checkout.php page:
@session_start();
if(!isset($_SESSION["svstate"])) {
$_SESSION["svstate"] = "".((isset($_POST["State"]))?$_POST["State"]:"") ."";
Here is the eCart Rule:
//eCart Rule
function WAEC_eCart1_SalesTax() {
$totalTax = 0;
if (true && (($this->GetTaxableTotal() > 0) && ((isset($_SESSION['svstate'])?$_SESSION['svstate']:"") == "NY"))) {
$totalTax += ($this->GetTaxableTotal() * 0.008125);//Result
return WA_eCart_FormatNumber($totalTax, $this->ForceDecimalsC, $this->DecimalPlacesC);
//eCart Rule
I have attached the files in the event you need, please let me know what I have done wrong
Note: 3/28/2015
I tried this solution but it did not work for me so I will await your reply
http://www.webassist.com/forums/posts.php?id=35117
sfranzken73972
Ok doing now
See private message
in the tax rule, you had been using:
$_SESSION['WASF_CheckoutWizard_Basic_Default']['State']
but in your case the checkout form was using the name "WASF_CheckoutWizard_NewFromBlank_Default"
so i updated the session to:
$_SESSION['WASF_CheckoutWizard_NewFromBlank_Default']['State']
for USPS shipping, I added code to the checkout page to write the session contents:
<pre><?php var_dump($_SESSION); ?></pre>
the response from USPS in the session is:
["eCart1_USPS_FullResponse"]=>
string(208) "
80040B1AAuthorization failure. Perhaps username and/or password is incorrect.USPSCOM::DoAuth"
the user ID you entered for USPS Shipping is not being accepted by the USPS server.
sfranzken73972
Thanks Jason
Sorry for the late response was at a meeting yesterday afternoon.
I will alert the client to check their USPS credentials.
Once I have them, rather then run the wizard again, can I just copy and paste them somewhere?
The USPS Shipping server behave is on the confirm_cart.php page.
open that page, and open the server behavior panel, then double click the USPS Shipping server behavior to edit it and change the user ID.
sfranzken73972
See Private Message
I have the information
sfranzken73972
Follow Up
See Private message
You are still getting an Authorization error for the shipping API...
I believe the current error is due to not being in "production" status at USPS.
Call 800-344-7779 and ask to be moved to production status.
sfranzken73972
Thanks Ray
This post has been deleted.
