WA_Auth_RulePasses() Fatal Error
Thread begun 8/29/2009 7:55 am by terry370125 | Last modified 8/31/2009 8:52 am by Jason Byrnes | 2106 views | 1 replies |
terry370125
I'm using Dreamweaver CS4, eCart 4.5.0, and SecurityAssist 1.1.7.
After selecting the "Submit Order" button on confirm.php in eCart, the following error appears:
Fatal error: Call to undefined function WA_Auth_RulePasses() in E:\webs\lsmontgomery.com\wwwroot\checkout_success.php on line 8
After reviewing another post to find a solution,the "Helper_PHP.php" line of code was added as the first line of the checkout_success.php page. The first few lines of the checkout_success.php page are listed below.
<?php require_once( "WA_SecurityAssist/Helper_PHP.php" ); ?>
//WA eCart Include
require_once("WA_eCart/eCartLS_PHP.php");
$eCartLS->GetContent();
require_once("WA_eCart/PP_ECO_Scripts/PP_ECO_PHP.php");
This did not resolve the "Fatal error" message.
Your help would be greatly appreciated!
Terry Montgomery
The WA_Auth_RulePasses() function is defined at line 144 of the WA_SecurityAssist/Helper_PHP.php
If you have placed the code:
at line 1 of your checkout_success. php page and are still having the same problem, one of two things is wrong:
1) The change you have made to the checkout_success. php page is not being properly uploaded.
2) The WA_SecurityAssist/Helper_PHP.php does not exist in the location that it is being looked for.
Try deleting the copy of the checkout_success. php on the remote server, then re-uploading.
